Swapping a B18A1 in, have questions
Old Jun 20, 2010 | 06:57 AM
justhatched231's Avatar
Icon2 Swapping a B18A1 in, have questions
What all do I need besides the hasport mounts, linkage and axles? does the A1 harness plug in on each side of strut towers or do I need a A1 harness all the way to the ecu? do I need a jumper harness? how do i wire for multi-point? What ecu do I need? Thanks for all the helP!
Old Jun 20, 2010 | 07:04 AM
EFRue57's Avatar
Default Re: Swapping a B18A1 in, have questions
depends on what you're plans are. I'm assuming this is your first time trying anything like this so to make things simpler use the 90-91 integra ecu and stay obd0. no you don't need a jumper harness. no, the a1 harness does not match up. you need to convert both your engine harness and your chassis harness from dpfi to mpfi. there are plenty of write ups on here that give you the steps on how to do that. just search a little. this is a very common swap and there is loads of info out here if you just take a few minutes to look for it.
Old Jun 20, 2010 | 10:47 AM
J.D.M_EF9_SI's Avatar
I just did a swap on my 91 si i didnt need much i just got the linkage cut and weld and also bought some motor mounts. Everything else got from a 91 acura integra everything fits just right you will run into the axles problem but what i did i got the whole front brake assembly and it runs good. pm if u have any problems.
Old Jun 20, 2010 | 10:50 AM
D16SiHatch's Avatar
pretty much everything you need to know
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/detailed-b-series-into-crx-ef-civic-parts-list-more-2769325/
Old Jun 20, 2010 | 05:12 PM
Thanks guys!
Old Jun 20, 2010 | 06:52 PM
soon2befast's Avatar
or maybe just buy a mpfi conversion harness off ebay iv been dealing with the guy that makes them for years
Old Jun 20, 2010 | 07:13 PM
link???
Old Jun 20, 2010 | 07:16 PM
D16SiHatch's Avatar
monotech on eBay used to sell the dpfi to mpfi setup but i can't seem to find it anymore. he still has this
http://cgi.ebay.com/ebaymotors/88-91...Q5fAccessories
but i don't know if he will also do a dpfi to mpfi conversion. suppose it wouldn't hurt to send a message and ask.
Old Jun 20, 2010 | 07:26 PM
ya all you have to do is email that guy and he will make u one up for 130 bucks or u can send him your dpfi harness and he will take of 30
Old Jun 20, 2010 | 08:08 PM
thank you!
SuperDan222
Nov 30, 2013 03:18 PM
DaIntegra1991
Feb 5, 2013 07:27 AM
therest
Nov 13, 2012 03:41 AM
ikaika3269
10
Feb 26, 2008 06:25 PM
