MD '94 Hatch, Aztec Green Pearl K-swap Ready Shell F/S.
Old Jun 19, 2010 | 11:43 PM
Froth's Avatar
Default '94 Hatch, Aztec Green Pearl K-swap Ready Shell F/S.
PAY NO ATTENTION to my location at the left, the Shell is located in: MARYLAND (MD).
CHASSIS: - Chassis has 141,XXX miles on it at the time of listing. Since the swap has sold this hasn't moved in a month or so. Please keep in mind that this is cut for a K-swap, so the Pass. Side frame rail bracket is gone and the shifter hole is also gone. I do have the metal to replace those items if You wanted to go through the trouble of doing that.
- 1994 Honda Civic CX hatchback, Aztec Green Pearl. (OEM Color/OEM paint)
Brakes:
- 1993 Civic Si Rear Disk brake conversion
- 1993 Civic Si eBrake cables
- 1994 Civic CX Front brakes (Same as my 93 Si...so I didn't swap them)
- 1993 Civic Si Proportioning valve (correct for disk setup)
- 1993 Civic Si Master Cylinder (correct for disk setup)
- Wire tucked(mild, just side harnesses)
Suspension:
- Koni Yellow adjustable (Painted flat black)
- 500lb/in Front springrate
- 650lb/in Rear springrate
- OEM Honda new trailing arm bushings
- OEM Honda new 1996 Del-Sol VTEC rear LCA's
- OEM Honda USDM ITR 22mm Rear Swaybar (Purchased NEW)
- OEM Honda USDM ITR Swaybar Endlinks
- ASR Rear subframe brace (Black)
- 1993 Civic Si Front Swaybar 21mm
- 1993 Civic Si Front LCA's
- Full race Pro-Street Traction bars
Wheels/Tires: (Two options, price increases with certain options)
- 1994 Civic CX OEM 13" Steelies with generic tires (Cheapest)
- 15x7 Borbet Type E's painted flat black with Kumho all-seasons
Interior:
- The ENTIRE Interior is from a 1993 Civic Si, minus the headliner.
- Rear Plastic Panels
- Door panels
- DASH (so there is no Airbag hole from being a 94, 93 dash was swapped in)
- Center console
- NARDI 330mm Deep-Corn Leather w/ Red Stitch steering wheel
- NRG Quick release
- NRG Short hub
- NRG Hub lock
- OEM USDM ITR Shift boot
- Stock 5spd shift ****
- Stock 1993 Civic si Cluster, 7200rpm redline and goes to 9k.
- Autometer gauges, mounted to the bottom left side of the dash(out of site, sleeper style) gauges are for Oil Temp(bung welded into oil pan!), Oil Pressure, and Voltmeter.
Seats:
- 1994 Del-Sol TEAL STRIPE on 1994 Civic Sliders (They match PERFECTLY)
Sounds:
- OEM Honda Integra CD player will come with the car.
- Decent speakers, Sony X'plods in the rear and Blaupunkt in the front
Exterior:
- eBay amber corners.
- eBay Spoon Carbon Fiber mirrors (Real CF, just not made by Spoon)
- 6000k "white" Retro-Solutions Hi/low 55w Bixenon HID's (Amazing)
- The pass side rear fender has been creased slightly, damage from previous owner. Crease is around 8-10" long
- The rear bumper has some scratches from being push-started, damage from previous owner. (has been touched up)
- Left front fender and door were re-painted due to being keyed. damage from previous owner. (good job, cannot tell difference in color)
On to the pics:
You can somewhat see the scratches in the rear bumper here, they're not very easy to see.
Closer shot of the area that is scratched, this bumper has been painted 2-3 times so it's not easy to tell where they are.
Quarter panel crease, the paint was not damaged(previous owner)
Closer/Angled shot of the damage.
Front fender and door of this side re-painted(car was keyed), you can't tell at all.
Steelies that the car would be $500 cheaper with, without Borbets.
PRICE:
- $3000 FIRM (with Borbet wheels.)
- $2500 FIRM (with steelies pictured.)
Thanks for looking
-Froth
Old Jun 20, 2010 | 07:58 AM
g2_teg_'s Avatar
Default Re: '94 Hatch, Aztec Green Pearl K-swap Ready Shell F/S.
looks nice. i told you to wait until July and i could buy the complete car...
pictures of the engine bay how it is now?
Old Jun 20, 2010 | 09:57 PM
srt4mike's Avatar
Looks great. GLWS
Old Jun 24, 2010 | 06:05 PM
Froth's Avatar
Thanks! Bump.
-Froth
Old Jun 27, 2010 | 08:26 PM
Froth's Avatar
Bump.
-Froth
Old Jun 30, 2010 | 08:23 PM
Froth's Avatar
Quick picture of the Bay as it sits now, Please ignore the Fuel Lines/FPR and Shifter cables...Those DO NOT come with the car as they are spoken for. You will however get everything else you see. The coolant lines/heater valve for the heater core will be included as is the Suja 1 clutch line and OEM hardline for an RSX-S Clutch Slave, The radiator mounts are also already moved over for a 1/2 size civic Radiator and the Throttle Cable will also be included('93 Si cable modified for K-swap use).
Picture is un-edited...there's a little surface grime on some things, but nothing serious at all.
-Froth
Old Jul 1, 2010 | 06:33 PM
Froth's Avatar
Bump.
-Froth
Old Jul 3, 2010 | 09:45 AM
Froth's Avatar
Quite a bit of interest recently, Bump!
-Froth
Old Jul 9, 2010 | 02:01 PM
Froth's Avatar
Bump, still F/S.
-Froth
Old Jul 9, 2010 | 09:05 PM
jpohl88's Avatar
Trade plus cash on your end?? Its got LSVTEC
Old Jul 9, 2010 | 09:10 PM
Froth's Avatar
Would depend on the amount of cash.
-Froth
Old Jul 10, 2010 | 03:13 PM
Froth's Avatar
Bump, still F/S.
-Froth
Old Jul 13, 2010 | 02:02 PM
Froth's Avatar
Bump, lets sell this. Price is O.b.o needs to be gone by the end of the month.
-Froth
Old Jul 14, 2010 | 05:04 PM
Froth's Avatar
Bump.
-Froth
Old Jul 15, 2010 | 03:51 PM
Froth's Avatar
Bump! Lots of interest but nothing set in stone. Lets sell this!
-Froth
Old Jul 17, 2010 | 04:00 PM
Froth's Avatar
Bump.
-Froth
Old Jul 22, 2010 | 08:37 PM
Froth's Avatar
Bump.
-Froth
Old Jul 22, 2010 | 08:56 PM
b18cKoupe's Avatar
nice
Old Jul 22, 2010 | 09:19 PM
BOOSTED EG6's Avatar
bump
Old Jul 23, 2010 | 02:30 AM
KillAhKev's Avatar
BUMP !!
ANY1 SELLING A CIVIC HATCH 92-96 AROUND $1-$900 LMK ASAP
NEED A ( AUTOMATIC CIVIC HATCH ONLY ! )
Old Jul 23, 2010 | 04:22 PM
Froth's Avatar
GTFO.
Bump.
-Froth
Old Jul 26, 2010 | 04:38 PM
Froth's Avatar
Bump.
-Froth
Old Jul 27, 2010 | 12:33 PM
SilverGT's Avatar
check your pm.
Old Jul 27, 2010 | 06:35 PM
Froth's Avatar
Bump.
-Froth
Old Jul 29, 2010 | 08:29 PM
Froth's Avatar
Bump.
-Froth
