Titanium rods
Old Jun 19, 2010 | 10:43 PM
daigo's Avatar
Default Titanium rods
Anyone have any experience with Titanium rods? I know Eagle is making them and there was a thread about the OBX offering but never from anyone who tried them.
Old Jun 20, 2010 | 11:09 AM
JLSpecialties's Avatar
Default Re: Titanium rods
You have to take some special precautions with ti rods. Titanium doesnt expand as fast as steel with temperature. So you have to run more bearing clearance then traditional steel rods. I would not set up ti rods tighter then .0022" of clearance, just to be on the safe side. Make sure you properly lubricate the bolt threads also, as ti like to gall.
I havent tried eagles ti rods or obx. Titanium is notch sensitive so Ive only used higher end rod manufacturers like Crower, Cunningham, MGP, or Oliver. If your willing to fork out the money for Titanium go with one of them.
Old Jun 20, 2010 | 11:11 AM
jv88_dc2's Avatar
I know Jakespec is using some Ti rods in his crx. His videos can be found on youtube under jakespec420!
Old Jun 20, 2010 | 11:17 AM
S2Integra's Avatar
They do have less thermal expansion but I also belive they have greater thermal breakdown. The heat cycles can effect the titanium's durability more so than a good steel. I have heard that some coat the rods to dissipate heat away from the rods. Or boost, you shouldn't pair is on a boosted motor according to some. Still, they can handle quite a bit, if you plan to build an extreme motor, consider titanium, if any less though it may not be worth the cost. As a side note I would consider these way before aluiminum rods.
Old Jun 20, 2010 | 11:18 AM
S2Integra's Avatar
I was also told the ITR uses a titanium alloy rods, but I have no way to prove that.
Old Jun 20, 2010 | 01:33 PM
thundernoodle's Avatar
spark white when you grindem
Old Jun 20, 2010 | 07:39 PM
Titanium does burn extremely bright. The thermal cycling doesn't adversely affect ti, after all it is used in the Z07 corvettes, I think porsche uses them too. And its used extensively in aerospace.
Old Jun 20, 2010 | 07:57 PM
victor.ek4's Avatar
NSX rods are Ti.
Aren't they?
Old Jun 20, 2010 | 08:54 PM
ShaunRR's Avatar
HT White Ops
Community Builder
The ITR does not use titanium rods, but the NSX does.
Old Jun 20, 2010 | 09:25 PM
PyroProblem's Avatar
Porsche GT3/GT3RS and Carrera GT rods are titanium...Very nice pieces.Had a picture of one somewhere around here...NSX also uses Ti rods...
I thought Eagle wasnt making Ti rods anymore?
Old Jun 22, 2010 | 07:05 AM
EG1834's Avatar
It's the Z06 that uses "titanium" rods in the 427ci LS7. They are not like the titanium aftermarket rods you'd find in a real race engine.
Regardless, I don't think there is enough heat through the rods to cause any adverse affects, however from what I've read they tend to distort more at high RPM.
Old Jun 22, 2010 | 08:36 AM
newtron63h's Avatar
i think titanium rods should only be used in VERY EXTREMELY serious applications. yes they have a higher strength to weight ratio than steel........BUT if you make 2 rods exactly the same, one Ti, one steel......the steel one is stronger. for a basic to moderate performance build, a street/strip car, even a weekend track car.........forged can do everything you need it to. once you start getting into extreme power ranges and continuous use is when you need to start thinking about crazy stuff like Ti rods and billet cranks.
Old Jun 22, 2010 | 09:01 AM
newtron63h's Avatar
i would think opposite about distorting at higher rpms. it was just said that they use Ti rods in the GT3 and GT3 RS, they redline at 8400rpm which is RIDICULOUS for a flat 6. i couldnt find any quick specs on that engine to give comparison numbers.
the LS7 in the Z06 redlines at 7000rpm which is crazy for a big pushrod V-8. and that engine has been repeatedly tested at 8000rpm. so with a 4" stroke @ 7000rpm the average piston speed is 4666ft/min and at 8000rpm its 5333ft/min. for comparison the F20C is only at 4960ft/min @ 9000rpm. the LS7 is throwing a much bigger bore(and probably heavier) piston around too so theres going to be more inertia getting slung around inside the LS7.
Old Jun 22, 2010 | 09:06 AM
Str8EJ's Avatar
Originally Posted by newtron63h
...if you make 2 rods exactly the same, one Ti, one steel......the steel one is stronger.
It really depends on the specific types of alloys being compared.
Regardless, the benefit is realized mostly through a reduction in weight, not a significant difference in strength. The ti part, again depending on the alloy, could weigh 30 to 40% less than its steel counterpart.
Old Jun 22, 2010 | 12:23 PM
newtron63h's Avatar
agreed, there are so many different alloys out there with very different properties and uses that you really cant say titanium, you need to get specific such as grade 5(the most commonly used titanium alloy). and yes the weight is the main advantage because Ti has the highest strength to weight ratio of any metal.
also someone mentioned earlier that it tends to break down with heat..........grade 5 for instance is commonly used in temperatures below 750F..............a temperature i hope the bottom end of your engine never sees.
jksmith
Dec 14, 2011 10:01 AM
rohec04
Nov 29, 2006 03:06 PM
V-SPEC 1
Dec 27, 2004 07:09 PM
Civicdrgrcr
Nov 19, 2002 04:47 PM
