window motor/reg
Old Jun 19, 2010 | 05:19 PM
IP RACING's Avatar
Default window motor/reg
I just finished installing my second replacement window motor and I'm running into the same problem once again. The first motor and reg worked for a week or so then started going slow and eventually stopped going up. This one looks like its on the same path already and its day 2. I have greased up the tracks and loosened the front track still same problem. Is there something else ,electrical wise that can be the culprit. thanks
Old Jun 19, 2010 | 05:50 PM
mortificationrock's Avatar
Default Re: window motor/reg
Well you dont grease up the tracks. You use some speacial silicone spray. I hope thats what you used. If not that would explain the sticking..
stealthtt24's Avatar
Did you replace the regulator as well as the motor? I replaced my back two regulators and motors because the plastic piece that attaches the window to the regulator. Haven't had any problems. I would test the motor to see if thats what is preventing it from working. If so, where are you getting the motor from?
raverx3m
Feb 28, 2014 08:26 PM
JustinE36M3
Jun 20, 2011 01:38 AM
rhdins
May 10, 2011 05:15 PM
brad8266
Jul 17, 2009 05:25 PM
