Obd1 B20B overheating issue
Hi I have a obd1 converted b20b in my 95 ex coupe I put my ls intake manifold along wit the rest of my ls parts onto my b20b. Today when I tried bleed the radiator for air bubbles anti freeze n white smoke came out of the top of the radiator where the radiator cap goes. Along witthat my radiator fan does not kick in I've tried connecting the wire from the radiator plug to the battery and the fan came on but besides that it doesnot turn on anybody got any insight on what the problem might be, thanks n thanks for readn this long *** muthafukkn threead
Check your Cooling Fan Relay. Not sure about the 96's, but the 92's its in the Fuse Box under the Hood. Try moving a relay that you know works into the Cooling Fan Spot and see if it works. If Cooling Fan does not turn on with a good relay, you could always run the Cooling Fan into a switch in the Dash.
Hope this helps.
Hope this helps.
Aiite so ibought anew cooling fan relay n when. I fired that sucka up the fan still didn't turn on also when thee motor is on it idles high at 3000rpm n holds there for about 10 min n smokecomes from the head/top of the headers ??
Dekorum
10
May 2, 2012 08:15 PM
hunter349
10
Jul 1, 2009 06:02 PM
95ProjectEJ1
15
Feb 1, 2007 03:09 PM
iNetForce
Mar 3, 2006 03:48 PM
