what are the best cams in a b16a for going all motor
Old Sep 13, 2002 | 08:47 PM
si power's Avatar
Default what are the best cams in a b16a for going all motor
as the topic says, what would you chose under $700. thanks
Old Sep 13, 2002 | 09:24 PM
ghettocrxsi's Avatar
Default Re: what are the best cams in a b16a for going all motor (si power)
ctr intake Itr exhaust... or some skunks or toda b's... the todas are liek 1000 or so though... and u need springs and retainers
Old Sep 13, 2002 | 10:18 PM
Faust's Avatar
Default Re: what are the best cams in a b16a for going all motor (ghettocrxsi)
When you guys say CTR, which year do you mean?
Old Sep 13, 2002 | 10:29 PM
johnzm's Avatar
Default Re: what are the best cams in a b16a for going all motor (Faust)
i say the skunk2 stage1. more agressive than ITR cams and valvespring upgrade isint required
Old Sep 22, 2002 | 07:04 PM
chirp2hrd's Avatar
Default Re: what are the best cams in a b16a for going all motor (johnzm)
would u need springs and retainrs for stage 2
Old Sep 22, 2002 | 07:27 PM
lazy bum shaughn's Avatar
They're all the same.
Only get those for mild power, if you want a little more power get the Skunk2 Stage I. For real power get Skunk2 Stage II with the built valvetrain, and you'd need some better pistons to get the best out of these cam.s
Old Sep 22, 2002 | 08:40 PM
Brandon Chun's Avatar
Default Re: what are the best cams in a b16a for going all motor (Breakdancer)
I like the ctr cams their mild, and a little bit more streetable, but if you want more power go for an aftermarket cam
Old Sep 23, 2002 | 01:22 AM
boostinb18's Avatar
Default Re: what are the best cams in a b16a for going all motor (Brandon Chun)
the best part about the CTR cams is that they dont need tuning like the skunks do......just drop em in and go! and they are also honda quality...i havent seena any broken CTR cams...have you?
Old Sep 23, 2002 | 04:12 AM
jdm_ef9's Avatar
Default Re: what are the best cams in a b16a for going all motor (boostinb18)
if you run both CTR intake/exhaust cams, do you need to run R springs and retainers? just wondering because most people say to but some of the guys at spoon say you need not to unless you plan on revving past 8500rpm. if i run those cams i just dont want to run into trouble down the road.
[Modified by orangeEF, 8:13 AM 9/23/2002]
psegs80
Feb 18, 2006 05:26 PM
blakacintegera
Jul 21, 2003 12:52 AM
2k1 GSR
Sep 7, 2002 09:57 AM
2k1 GSR
Jun 18, 2002 07:54 PM
far
Apr 4, 2002 09:52 AM
