High pitch noise coming from engine.
Old Jun 17, 2010 | 04:24 PM
JasonYo's Avatar
Icon3 High pitch noise coming from engine.
So when my engine is warm and only at idle it starts to make this high pitch whistling/squeaking noise. I know that it is not any of the belts or the intake. It is also not any of the vaccume hoses on the intake manifold.
Heres a video to see what it sounds like. You can hear it really well towards the end.
http://www.youtube.com/watch?v=VINMLaXpU4o
If anyone knows what it could be please help, it is the most annoying thing ever! And I cannot figure this out! Thanks.
Old Jun 17, 2010 | 04:47 PM
_eg6_'s Avatar
Default Re: High pitch noise coming from engine.
man thats a tough one gl
Old Jun 17, 2010 | 04:59 PM
JasonYo's Avatar
Ya I know lol. thanks.
Old Jun 17, 2010 | 06:57 PM
Former User's Avatar
Sounds like a bad pulley bearing. Use an inexpensive engine stethoscope to pinpoint the noise.
Old Jun 17, 2010 | 07:21 PM
JasonYo's Avatar
Alright I'll try to check those out.
Old Jun 17, 2010 | 07:24 PM
b1u3_5i's Avatar
Also check your alternator. If you can, start eliminating a/c, altrernator, p/s belts one by one, and see if the sound goes away. I hope this helps.
Old Jun 17, 2010 | 07:36 PM
JasonYo's Avatar
Well I don't have a/c, and I ran the engine with the alternator belt off so it's not that.
I might try disconnecting the p/s belt to see if its that.
Old Jun 17, 2010 | 08:38 PM
itsmejto's Avatar
cheap stethoscope = piece of hose.
Old Jun 18, 2010 | 07:28 AM
JasonYo's Avatar
Hmm yes, good idea!
I'll try to pinpoint the noise first, but I did listen very carefully for a while the other day and it seems to be coming from the cam pulley area or just behind. The noise is clearly not from the p/s area.
Is it possible that the timing belt is to tight or something?
Or could the pulleys be making this noise?
Old Jun 18, 2010 | 09:27 AM
Atomic1's Avatar
Try squeezing your pcv hose when it's making the noise.
Old Jun 18, 2010 | 09:32 AM
Hill4589's Avatar
Agreed. And I wanted to compliment you on how clean the engine bay is!
Old Jun 18, 2010 | 10:04 AM
BrandonR's Avatar
Honestly, it sounds like air whistling as it goes through the IACV passages. If you notice it only whines when the IACV opens up. I had a 5.0 Mustang that did that, as well as many other 5.0's. Take off your IACV and sand the sharp edges down slightly.
Old Jun 18, 2010 | 10:12 AM
blackKready's Avatar
yeah its definitely air. soon as you give it even the littlest throttle it goes away.
Old Jun 18, 2010 | 01:32 PM
JasonYo's Avatar
I'll check the IACV, I was told it was a air leak or something for sure.
Old Jun 18, 2010 | 01:34 PM
JasonYo's Avatar
Thanks! I try to keep it as clean as possible.
Old Jun 18, 2010 | 01:36 PM
The locations of the sound and IACV aren't a good fit.
Old Jun 18, 2010 | 01:49 PM
JasonYo's Avatar
Yeah, well the sound is more towards the rear drivers side of the engine. It's not at all near the tb. So it's probably not that.
Old Jun 18, 2010 | 01:53 PM
Sounds like the alternator. As already mentioned, remove the alt belt to see if the sound goes away.
Old Jun 18, 2010 | 09:27 PM
JasonYo's Avatar
Yeah I did that and the sound didn't go away!
A lot of people have been telling me that it sounds like a air leak, not bad bearings. I don't know tho.
Old Jun 19, 2010 | 05:40 AM
JasonYo's Avatar
Someone said that it could be a intake valve leaking. Is this possible?
Old Jun 19, 2010 | 06:05 AM
Seriously, I paid only $4 for an engine stethoscope at Harbor Freight Tools.
Old Jun 19, 2010 | 02:14 PM
JasonYo's Avatar
Well I'll get one it's just that I work everyday except sunday and I can only work on my car at night. Stores are pretty much closed when I'm off.
I guess i'll just wait until then.
Old Jul 15, 2010 | 02:13 PM
JasonYo's Avatar
Any more Ideas as to what this might be?
Still haven't figured it out, and don't have the time to do anything big like take my engine apart. =/
Old Jul 16, 2010 | 10:16 AM
Dymond's Avatar
That's a clean *** engine bay
+1
Old Jul 16, 2010 | 09:53 PM
JasonYo's Avatar
Thanks!
