idk what to swap in my ek4 hatch plz help!!
I have 1500 and idk what to swap in my hb. I want a h22 but how much more would i want to save? And what parts do i need to get if i get a h22? i noe u need axels, tranny and a ecu. thx.
lets see with the basic, you need.. custom h series brackets for the hb custom radiator i believe n other whatnot check their are many threads on h swaps.
^^^lol. I can see puting a H22 in your car is gona cost a little more then 1500 unless if you know where the deals are.
Here's a good thread btw.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%2A%2A%2Ah22a-into-civic-eg-ek-information-post-all-h22a-hybrid-info-here%2A%2A%2A-650329/
Not really. You're going to need the same basic parts for any Honda engine swap. Engine, transmission, axles, mounts, ECU, wire harness, radiator hoses.
Just with the H-series you're going to need aftermarket mounts. Wiring might be a little more extensive, but that could depend on the engine and car choice.
i was looking into a h22 swap for my civic but i went b series swap instead because its cheaper but an h22 swap is very nice and it needs more work than any b swap. it would be easier if you get the wiring harness that matches the engine and swap that main harness into your car IF YOU DONT MIND SOME ELECTRICAL THINGS NOT WORKING!!! you would be able to do everything yourself if you go this route
A radiator support would be the same as the core support, which is the entire front frame piece of your car.
This, the whole front part:
i have looked into the h22 before. what you would need is a slim fan for your radiator since the headers of the h22 wont let you have the fan. as far as mounts,ecu,and axles it would be easier if you put the h22 body main harness so you dont have to repin any wires
4 Dr Swap It
Mar 14, 2003 05:42 PM
