ZC + 5SPD L3 Tranny How can i figure out what axles I have...
Old Jun 16, 2010 | 10:59 PM
xymantec's Avatar
Default ZC + 5SPD L3 Tranny How can i figure out what axles I have...
I have ready that you can use your DX/Si Hubs but I have a 91 DX and it wont fit the axles i have seem to be a bit too thick, this setup was in my old CRX before it was wrecked so i know this was on a CRX.
I need to find out what axles I have so i can get the hubs that fit them.
Please help.
I have a L3 5SPD
Thanks
Old Jun 17, 2010 | 12:14 AM
TheEf2Kid's Avatar
Default Re: ZC + 5SPD L3 Tranny How can i figure out what axles I have...
Please help.
I have a L3 5SPD
Thanks
all d series axles are same. length, width, diameter, etc are you sure the hubs are si/dx not Hf. i heard hf hubs are different.
Old Jun 17, 2010 | 12:46 AM
xymantec's Avatar
To be honest I am not sure because it currently had a d15B2 + Tranny which i believe is a DX all the wiring in the car was DX thats why i find it strange that the Hubs would be different. this maybe a JDM L3 I am not sure I am hoping to find out. I did count the splines on the L3 Axles which equal 26 and the ones on the dx tranny are 27 or 28 if that helps.
Old Jun 17, 2010 | 12:50 AM
TheEf2Kid's Avatar
hm.. strange never ran into a problem like this. good luck bro.
Old Jun 17, 2010 | 12:52 AM
xymantec's Avatar
well if i can find 26 spline hubs they should work right? as long as the ZC axles have 26 splines?
Old Jun 17, 2010 | 12:55 AM
TheEf2Kid's Avatar
k you lost me. what axles are you using? the one off your car or the ones that came with the swap?
Old Jun 17, 2010 | 01:00 AM
xymantec's Avatar
Let me explain:
Currently in the car is a d15b2 Mini Me, I am assuming the transmission is a DX tranny.
Outside I have the ZC SOHC with the L3 Tranny attached. I tried putting in the ZC axles in the current hubs and the axles seemed to big. I wonder of the dumb****s who had it before decided to put HF Hubs with a HF tranny. I am just thinking if I buy new knuckles with hubs for 91 SI they should fit (26 Spline).
Old Jun 17, 2010 | 01:04 AM
TheEf2Kid's Avatar
why spend more money just use your tranny you have on the car. make it easier on yourself. transfer your tranny on to the zc. and just sell that unknown tranny. besides guessing on what hub to get.
Old Jun 17, 2010 | 02:31 AM
BiG ChOr!Zo's Avatar
just let me have that dx tranny and ill figure it out
Old Jun 22, 2010 | 07:48 AM
jlicrx's Avatar
sounds to me like your car is not a DX model but is actually a STD model which had the smaller hubs like the CRX HF
Old Jun 22, 2010 | 01:36 PM
xymantec's Avatar
Yeah after doing hours of googling I have come to the same conclusion, I just got my SI hubs and arms today so i will be putting those on.
Thanks for your help.
Hope this helps someone in the future who stumbles on this same problem...
Old Jan 21, 2013 | 10:27 PM
Los guy's Avatar
Ok I have a similar problem I bought a L3 trans and bolted it in to my 91 civic lx and my D-series axles are to small for the tranny diff holes. Anyone know what axles I can use? Keep in mind I don't have the intermediate shaft nor a place to bolt in an intermediate shaft. Please advise.
Old Jan 24, 2013 | 12:55 AM
swordofdoom's Avatar
L3 5 speed uses the 89-91 civic 1.6L 26 spline axles. This should bolt directly on.
Old Jan 24, 2013 | 06:48 AM
alex1321's Avatar
ZC tranny are also L3 5 speed, the splines in tranny are just bigger so you need absolutely the ZC midshaft but you can use 93 integra axles they will fit into the tranny and the hubs and the midshaft. I Had same problem. That could help you alot. http://www.thezcr.com/forums/attachm...5&d=1216608214
Old Jan 24, 2013 | 09:31 AM
ChokolAwt's Avatar
you can use your si axles in a zc transmission. i did. the hf/std are the odd ***** when it comes to front brakes/axle combos
Old Feb 19, 2020 | 10:55 PM
Ricardo Rodarte's Avatar
I have a problem finding 23 spline wheel hub I have a l3 trans 5 speed and my spline count on axle wheel hub side are 23 I was wondering is I can just change out the axle and wheel hub for a bigger size ? Or leave as is and find new hubs?
Old Feb 20, 2020 | 06:43 AM
jlicrx's Avatar
is this a ZC transmission or just a regular old L3 5-speed? - if it is not a ZC, you just need axles for a 88-91 CRX HF or 88-91 Civic STD model - STD is the 4-speed model - since you have 23 spline hubs, do you already have a Civic STD or CRX HF? if so, just use your axles
if it is a ZC transmission, you need the larger spline hubs, a ZC intermediate shaft and 90-93 Integra axles
buckweeb101
Jul 3, 2013 12:52 PM
91sihatchback
Jul 12, 2004 07:56 AM
terminaloverlowd
Jun 17, 2004 02:23 PM
projectcrx
Mar 26, 2003 09:57 PM
zcivicz
30
Apr 15, 2002 02:29 PM
