Car cranks but doesnt start?
I have a 91 Sedan with a sohc zc. Just recently did my mpfi swap. Car ran perfectly fine for a few days and then it just craps out on me while i was slowing down for a stop light. There is no spark going to the spark plugs and the fuel pump doesnt kick in and i dont hear a buzz when i turn the key. I also found out that there is no power going to my ecu. The car cranks but it doesnt start. I'm thinking that it's the main relay but im not entirely sure. Does anyone have any idea on what it could be?
check you main relay. turn your car on accessory and listen for a click sound on your bottom left side of your dash. if you don't hear and click sound then drop down your main relay. and turn it on and off accessory see if it click.
check your grounds on the thermo housing above the starter. they are bolted on by a 10mm. if loose you will lose power to the ecu. there for causes the lack of spark, no fuel pump, no power to the main relay. If it was in fact the alternator or battery the ecu will make a long buzzing sound........
Just checked the ground that goes to the thermo housing and its still there. And im not sure where the one in the trunk is. Im thinking about taking out the main relay tonight and checking it out.
The battery is good and was just replaced last august. I also looked around the intake manifold and all the wiring and everything looks solid. I'm pretty much stuck and dont know what else it could be.
no power to ECu.... if the fuses are good including the ECU fuse i would think one of your grounds is loose/bad... no ground no completed circuit for power to be delivered to your ecu ... check for loose connections (plugs) and grounds. also , try a different ecu.. i cant really remember but theres a ground circuit in the ecu that could of gone bad.
Hope you get it goin soon
hey.. i got a 1990 honda ef..
i drove it fine for a month..
then i try to turn it on then
out of no where the car didnt start..
i thought it was the fuel pump..
checked it and got the fuel pump
straight to the battery source with
a on off switch to get the pump going..
now it got the fuel pump working..
but i was getting low energy to the
fuel pump wires.. very little and
dont know why.. and i dont use the wires
no more so i have the battery source still..
if any one knows
plz let me know...
if any one knows
plz let me know...
