Suspension & Brakes Theory, alignment, spring rates....
brake upgrade for 93 civic si non-abs
Old Jun 16, 2010 | 08:23 PM
X93siX's Avatar
Default brake upgrade for 93 civic si non-abs
im starting to get the typical spongy brake feel and i wanna upgrade to get some better stopping power.
im pretty sure a bigger MC and brake booster = better stopping power.
looking for an oem upgrade (maybe a 1" MC) and id appreciate any info you guys would share.
also dont mine bending some lines and reflaring.
thanks guys.
Old Jun 17, 2010 | 09:11 AM
roastbeefrichie's Avatar
Default Re: brake upgrade for 93 civic si non-abs
yes, most likely is your master cylinder going bad.
if your front brakes are stock, i'd recommend that you stick with a 13/16" MC,
get good pads, blank rotors & fresh brake fluid.
Master Cylinder relative to the Caliper
When you go to bigger caliper than use a larger piston, you are pushing more fluid through the brake lines. Therefore, you should want a larger master cylinder to push this more fluid.
General rule is…with your stock Civic DX, with the stock front calipers, keep your 13/16” MC. Any bigger and your pedal will be too stiff.
Old Jun 18, 2010 | 07:01 AM
X93siX's Avatar
rad, thanks for the info.
Old Jun 18, 2010 | 10:30 AM
X93siX's Avatar
what about the brake booster?
i wanted a little better braking power with stock caliper, pads, etc
Old Jun 21, 2010 | 10:28 PM
2000csi's Avatar
do an integra brake upgrade, i just did mine and love it. having the rear disc and bigger rotors in the front helped stopped my car alot quicker with ease too.
Old Aug 15, 2012 | 04:16 PM
t.tran19's Avatar
Sorry, I know I'm a little late on this thread, but I have the same exact car (93 civic si) and was planning on doing just a cheap oem upgrade too. Was wondering what did you end up doing? Did you upgrade your brake booster too? Thanks!
Old Aug 15, 2012 | 10:55 PM
egsleepercivic's Avatar
i have a 93si and plan on doing either teg fronts or the sir eg6 fronts (same as del sol vtec) 10" fronts and the 91 si MC 15/16ths from this thread https://honda-tech.com/forums/suspension-brakes-54/15-16s-master-cylinder-3079258/ seems like it would be a good oem upgrade
hope this helps
fkjaccord
Sep 10, 2013 11:46 PM
mrNewt
Suspension & Brakes
Jun 7, 2011 05:08 PM
ThaCivicAssassin
Aug 12, 2007 12:26 AM
mingchi69
Jun 21, 2003 11:47 AM
bruvaman
Jul 9, 2002 07:19 PM
