Slim Fans Worth it?
Old Jun 16, 2010 | 08:00 PM
mortificationrock's Avatar
Default Slim Fans Worth it?
Well im gonna be in the market in the next month or so to buy a new Radiator. Since i have a measly 1core rad on my b18b. And i want it to be a little more cool. So im gonna get a 2 core one. Or the fatter one what ever you want to call it. So i was also looking into maybe buying a slim fan too. but im not sure if these things are even worth it. Or if they actually make the car cooler. Or if they dont crap out fast. So anyone with experiences on these items chime in to help me make a decision.
Also any pointers on where to buy some legit ones let me know. Even if its ebay. I rather buy from someone that you guys have had a good experience with. Then buying it from some random vato.
Old Jun 18, 2010 | 04:05 PM
Default Re: Slim Fans Worth it?
Damm 42 views and not one reply?
Old Jun 18, 2010 | 04:28 PM
russlan44's Avatar
i got slim fans in both of my cars, h22 civic and turbo del sol, so far so good + using civics oem radiator, if i would keep my cars i would upgrade to thicker aluminum radiator. They cool down fast but they turn on more often sense im using civics rad
Old Jun 18, 2010 | 04:52 PM
BlackEM2's Avatar
slim fans are mainly if u need the extra room with the wider radiator ...or aftermarket header/ or maybe a turbo set up i dont think they keep it any cooler than the stock ones unless of course they are bigger size fans
Old Jun 18, 2010 | 07:21 PM
deadazleep's Avatar
got a ebay special pusher/puller on my fluidyn, preparing the bay for turbo. Havnt noticed a advantage on the temp gauge but the slim fan is louder and leaves plenty of room under the hood
Old Jun 18, 2010 | 07:26 PM
Hmmm....good to know stuff. Well my fan is old *** hell so im gonna go ahead an upgrade both the fan and radiator.
Old Jun 18, 2010 | 09:09 PM
Jimmy's Avatar
Global Moderator
It all depends on the CFM the fan pushes. Don't crap out and buy a cheap fan.. I'd get something capable of 1200 cfm.. Should keep your engine nice and cool.
Old Jun 19, 2010 | 12:42 AM
thumper64's Avatar
OEM fans are good and cheap if you can use it...
Ebay radiators are good...just don't use the petcock at the bottom, that's their weak spot.
Old Jun 19, 2010 | 01:50 AM
mayfly's Avatar
go with FAL fans. and a koyo radiator if you want one kick *** set up that also has reliability
Old Jun 19, 2010 | 01:55 AM
chinochanginc's Avatar
I'm currently running an eBay fan on my oem radiator. Made no diff. Just more bay space and like some one above said it's louder. Then again u can get a 14 inch slim fan on eBay for $24 shipped. So why not..
Old Jun 19, 2010 | 01:59 AM
mayfly's Avatar
or get FAL fans and have reliability and performance.
Old Jun 19, 2010 | 02:01 AM
mayfly's Avatar
its hard to see the gains from the fans. you will mostly see your cooling gains from your radiator. get a koyo. you will not regret it. do it right the first time
Old Jun 19, 2010 | 12:27 PM
Well there was this sponsor on here selling both a slim fan and a dual core rad for 120 shipped i believe. Thats why i asked
Old Jun 19, 2010 | 12:36 PM
Red_Army's Avatar
thats pretty low and sounds a little risky.
even my mishi rad/fan combo was a lil over 200. and i only did that cuz i didn't have time to save up for a koyo and FAL fan. works all the same though for now.
only downside is wiring up the fan since it comes with dumb connectors.
Old Jun 19, 2010 | 01:05 PM
Jimmy's Avatar
Global Moderator
Snip the dumb connectors and wire it in to the factory fan harness plug, use heat shrink and be done with it.
Old Jun 19, 2010 | 02:12 PM
Red_Army's Avatar
and thats what i did. then tucked it up by the foglight with it being a little long. just another step thats all.
Old Jun 21, 2010 | 05:52 AM
blowededup's Avatar
Two wires to cut and solder together...no biggie. I cut the harness off the OEM fan itself, connected that to the Mishimoto fan I have now and simply clicked it in to the body harness like it was stock.
JDM97R
Apr 5, 2005 11:31 AM
gsr4doorboostin
Mar 28, 2005 10:09 AM
Elkins911
May 6, 2004 03:56 PM
B18C Hatch
Oct 17, 2003 07:25 PM
