cable to hydro write ups, have there been any done?
I used hasport cable to hydro conversion. U gotta use the da rear bracket and have the bottom two bolt holes drilled out to fit the 2 19s. Gotta change the driver side axle seal if using da axles. That's all I think
Because the hydro tranny use 19's and cable uses 17's and the bracket is made for the 17's so it needs to be drilled out. Axle seal because it's different half shaft. I had to change the seal using the da axles then it had to be changed back to stock to run dc axles
I started thinking about. Did you mean a hydro trnny in a cable car because that's what I am talking about.
Sorry if you mean the other swap
jontsi95
Mar 17, 2008 12:09 PM
Radyjr
May 12, 2006 10:50 PM
92, cable, car, civic, conversion, difference, diy, drilled, half, hydro, odnoklasnikiru319750html, poontang, shaft, step, transimission, transmission
