How the F do I get this out?
Old Jun 16, 2010 | 05:48 PM
Corksil's Avatar
Default How the F do I get this out?
Hey, workin on a car. changing oil seal behind timing pulley on bottom of motor.
this pin has to come out before the pulley/gear comes out.
this pin is stuck.
this pin is pissin me off.
I've tried low heat, pliers, hammering from all directions, vice grips, cussing, punching, verbal abuse, and seduction.
what haven't I tried and how the Fvck am i gonna get this b!tch out. don't want to leave my car on jackstands for days .......
thanks HT
(btw this is a corolla, but who cares, the question still applies.
Old Jun 16, 2010 | 05:50 PM
Corksil's Avatar
Default Re: How the F do I get this out?
btw i even poured beer on the pin in a desperate attempt to get these parts to loosen up and let go and just fckin relaxx and do what they are sposed to.
and i had a stripper come over and do a dance but that mighta just made this pin harder >.<
any suggestions welcome, i'm about to drill this mvthafvcka out in a fit of rage.
Old Jun 16, 2010 | 05:54 PM
robfrmny21's Avatar
LOL. TRY PUTTING SOME BRAKE FLUID ON IT. IF YOU HIT IT WITH ANYTHING MAKE SURE IT IS BRASS SO YOU DO NOT DAMAGE THE KEY OR CRANK
Old Jun 16, 2010 | 05:59 PM
PSU's Avatar
PSU
formerly DxHatchback
^ HOLY CAPS LOCK Batman.
Old Jun 16, 2010 | 06:03 PM
Nichelson_Performance's Avatar
hahahahahahahahahahahaha, sound like my kind of attitude only i wouldn't waste beer on it.
anyhow did you try taking a small flat chisel and and tapping under the edge of it cause it looks like a half-moon style keyway and that usually works for me, but it also looks as if the gear is supposed to come off first then the key
good luck man
Old Jun 16, 2010 | 06:31 PM
D16SiHatch's Avatar
friggin hysterical. totally worth making this reply lol. like nichelson said i think sticking something like a small flathead screwdriver under the opening and jamming it in there is probably your best bet to pry it out.
ABCVTEC
Nov 19, 2010 02:20 PM
zirac50
23
Sep 3, 2009 09:29 AM
sean burke
May 20, 2009 12:35 AM
wickedplastikman
Nov 8, 2004 10:49 PM
gulf imports
Aug 16, 2003 02:26 PM
