Got a REF ticket, Which engine can i put in for cali inspection LS?
Old Jun 16, 2010 | 01:50 PM
LastGenEK's Avatar
Default Got a REF ticket, Which engine can i put in for cali inspection LS?
Well I recieved a ref ticket and im thinking of selling my turbo gsr
Do I need a 0bd2a or obd2b
The car is a 2000 civic ex 5 spd
complete setup for sale or trade for si engine must be stock engine no mods (the si will be easyer because of the harness)
Old Jun 16, 2010 | 03:25 PM
mortificationrock's Avatar
Default Re: Got a REF ticket, Which engine can i put in for cali inspection LS?
Why dpnt you just remove turbo? What year is ur engine?
Old Jun 16, 2010 | 04:53 PM
Old Jun 16, 2010 | 05:13 PM
98civdx's Avatar
Master Detailer
Pull the turbo and just keep the gsr.
Im just guessing but becasuse your car is obd2b you need obd2b, someone corect me if im wrong.
Old Jun 16, 2010 | 05:21 PM
ekb16's Avatar
obd2 is a PITA to pass but if u have the right parts you can. you will need to convert to obd2b and find yourself a p72 that is obd2b and have the immob removed
Old Jun 16, 2010 | 05:26 PM
raidacaipo's Avatar
California boy? No good.. not good at all.. I don't think they even allow Integra B swap motors into civics no more unless yours was already BAR'd. Your best luck is to find a 99-00 Civic Ex motor or a 99-00 Civic USDM b16a2 motor if you plan to BAR it.
"If you build it, REF will come"
Old Jun 16, 2010 | 05:53 PM
SeanK325's Avatar
true. it's hard out here. if i'm not mistaken ANYTHING other than what is installed by the factory is an illegal modification unless you get it BAR'd. for your 2000 ex, you need a D16y8. hell, you can't even had HID's (they suck anyway), and you're car needs to be a certain height.
that quote is funny!
Old Jun 16, 2010 | 06:08 PM
gotbooost's Avatar
LastGenEK what are the details on the motor? and are you selling it with the turbo?
Old Jun 16, 2010 | 06:13 PM
fungus mungus's Avatar
I don't know where all of this is coming from...of course you can put aftermarket parts (intake, header, intake manifold, etc), as long as they have CARB EO numbers. This is nothing new and it certainly hasn't changed. And yes, of course you can BAR a GSR in a '00 Civic...if you have an '00 or '01 GSR motor. If you don't...well, that sucks for you.
If you do have an '00 or '01, by all means, pull that turbo off, go over the swap with a fine-toothed comb and get the thing BAR'd. Then put your turbo on again and try not to get pulled over again.
fm
Old Jun 16, 2010 | 06:22 PM
raidacaipo's Avatar
fm
are you from California?
Old Jun 16, 2010 | 07:13 PM
"The Golden State" is the motto of what U.S. state?
fm
Old Jun 16, 2010 | 07:24 PM
SeanK325's Avatar
yeah, parts that have the CARB tag on them already are obviously legal, but we're talking about full engine swaps. OP has issues...
Old Jun 16, 2010 | 07:26 PM
My BAR sticker for my B18C1 in my EG, received in Feb 2010:
Old Jun 16, 2010 | 07:27 PM
Like I said, if the OP has a 00 or 01 motor, they're fine...they just need to remove the turbo and take it to the REF to get BAR'd. If they put in an earlier motor...it sucks to be him.
fm
Old Jun 16, 2010 | 07:31 PM
SeanK325's Avatar
so wait, you can't BAR a motor from an earlier year?? i've never heard of that before.
Old Jun 16, 2010 | 07:38 PM
No, the motor has to be out of the same year car or later. Whether it came from an Integra or not is irrelevant. What you can't do is put in a B20 since that's considered a truck motor, and the rules specifically prohibit putting truck motors into autos. A hybrid (LS/VTEC) is no good either. But a straight B16 or B18/B18C1/5 swap is perfectly legal.
fm
Old Jun 16, 2010 | 07:54 PM
SeanK325's Avatar
fm
good to know. live and learn!
i knew that about the b20 not being legal though. i just never knew it had to be from a later year. damn, so that means i have to find a 98> type r motor...
Old Jun 17, 2010 | 07:43 AM
blkcivic310's Avatar
WELL (fungus mungus) is 100% right jsut to add you cant reff JDM motors so if you do find a 98 type r has to be USDM and then just wire everything up as close to OEM specs for the motor i just passed in feb and yes i live in cali i reffed a 97 gsr in my 95 civic coupe
Old Jun 17, 2010 | 08:58 AM
LastGenEK's Avatar
I need a completly new motor this will not pass at its
*built with lowerd compression
*1995 JDM GSR 0bd1
*and yes you can put B series motor in
Im willing to trade a complete swap b16a2 or equiv
What we will do is if you car is nice enough we can trade cars
My car is super clean with remote starte, turbo timer , navi double din, si wheels, clean paint
or
we swap engines and wire harness, ecu bla, bla (we keep are transmissions)
My engine starts perfectly with only .3 seconds of cranking time on the alarm
and comes with,S300 already tuned,4bar map, its ready to roll
Yes i will sell just the motor setup with turbo but would rather swap engine
Old Jun 17, 2010 | 09:04 AM
Mrhiguy's Avatar
It's actually a very simple process.You make sure you install every smog component from a 2000-2001 GSR into your Civic and you're done! Don't worry about the year so much. The hardest part of the swap is making sure the EVAP system works correctly.
Old Jun 17, 2010 | 09:16 AM
Just FYI the first thing the reff checked was the year of the motor
And I wish my motor was a year newer cuz ide for sure trade you my gsr.
Old Jun 17, 2010 | 09:47 AM
Mrhiguy's Avatar
Depends on which Ref you go to. Some will just make sure it's at least an obd2 engine and allow you to equip it with the required smog.
BTW. I worked at the Referee for 2 years
Old Jun 17, 2010 | 09:50 AM
^^ yea good point all reffs look for diff things
Old Jun 17, 2010 | 09:52 AM
Mrhiguy's Avatar
Hey LastGenEK. Where in Cali do you live?
Old Jun 17, 2010 | 09:55 AM
Mrhiguy's Avatar
BTW. The same amount of work will required to legally put either a b18b or b18c1. You've already got the hard part done Since you already have the C1 drivetrain.
