b16a block and parts, gsr parts, dsm turbo related parts
Located 30 minutes south of chicago
GSR b18c1 Thermostat housing - $10 http://i420.photobucket.com/albums/p...e/DSC00096.jpg
GSR Water pipe/ coolant pipe - $15 http://i420.photobucket.com/albums/p...e/DSC00100.jpg
GSR Oil Cooler - $10 http://i420.photobucket.com/albums/p...e/DSC00101.jpg
b16a JDM cams - 1 of the cams has very light rust on 1 portion of the lobes over 1 of the cylinders, however it is fixable with light sanding or taking to a machine shop. Price is $25 for both cams http://i420.photobucket.com/albums/p...e/DSC00106.jpg
b16a oil pan $50 (if you want the girdle and filter its $75) http://i420.photobucket.com/albums/p...e/DSC00110.jpg
B series Starters. Napa one is $25, OEM Honda one is $30.
http://i420.photobucket.com/albums/p...e/DSC00094.jpg
http://i420.photobucket.com/albums/p...e/DSC00098.jpg
Sensor or possibly a fan switch, in perfect condition, I forgot what it is because I haven't touched the sensors on my car in over 2 years. - $10
http://i420.photobucket.com/albums/p...e/DSC00105.jpg
B series motor mount just the drivers side mount - $25 http://i420.photobucket.com/albums/p...e/DSC00099.jpg
B16a block with water pump, timing belt, and all other accessories on the right side still attached and Crank Shaft still in block, in perfect shape ready for a hone/deck and to go turbo. My friend is going to buy it, however is taking forever. First person with $200 cash gets it. (willing to throw in original pistons and connecting rods, connecting rods are perfect, pistons need to be resurfaced) http://i420.photobucket.com/albums/p...e/DSC00102.jpg
1g DSM turbo manifold - has outside heat cracks but they are only on the surface and are no where near all the way through (perfect for grinding away the rust and then heat coating and porting the inside) $25 http://i420.photobucket.com/albums/p...e/DSC00140.jpg
1g DSM talon eclipse gst gsx laser stock Intercooler piping - no leaks what so ever - $25 http://i420.photobucket.com/albums/p...e/DSC00141.jpg
