B16a swap into a 97 dx coupe**help**
I just got a 97 dx coupe and want to swap in my b16a. The b16 is set up for obd1 and was pulled out of a eg coupe and i still have the whole swap. Im new to the ek's and need some help on what i need to get to make this work, i know i need a obd2 alternator, distributor, y8 wiring harness and jumper harness obd2 to obd1 but as far as shift linkage, motor mounts and stuff like that im lost. Can i use the shift linkage that i pulled with the swap? Do i need all new mounts or just the driver side mount? Anybody thats ever done this swap please help i just need a list of things i need to get this done..............
Please bump if viewed......thanks
for the Mounts u could use all th stock Mounts on the 96-00 civic
to all u need is 99-00 civic Si T Bracket and the 99-00 Civic SI timming belt Bracket to drop the swap in the shift linkage could be used to make it obd2 ure gonna need OBD2 Alternator ,Distributer,Injectors,Ecu u could use the stock civic engine harness just gonna have to wire up the VTEc and a couple other sensors real easy swap to drop in......
here is a link to the timming belt bracket
http://www.ff-squad.com/tech/mounts/ek.dualpost.jpg
here is a link to the T Bracket
http://www.vlatstore.com/NEW%20SITE/OEM%20HONDA/60.jpg
user 996328629
Sep 21, 2005 11:24 AM
