2.0 ITR piston troubles. HELP
I am having trouble locating the correct piston for my setup.
-B18C Darton MID sleeved to 85mm
-Eagle 5.433 H-beam rods (stock ITR length)
-Stock ITR Crank
It is very possible I am thinking to hard on this one. Essentially this engine is just a bored out ITR. The reason I am getting confused is because every piston catalog I look at refers to all the 84mm+ pistons as having to be used with 89mm stroke and a 5.290 rod. But the more I think of it, aren't the pin location in all B series pistons the same? (excluding long rod setups like Endyn). Basically what I need is a 12.2-12.5:1 coated piston. But I want to make sure I order the right piston.
Sorry if a fubard your brain reading this junk. Maybe some of your more experienced 2.0L builders can chime in. And while were on the subject, I'll take some suggestions on a set of camshafts that will get me in the 230whp range.
Thank you all for your time!
-Stock ITR Crank
Look here.
http://www.jepistons.com/Catalogs/Sp...ura/b18c1.aspx
I was also thinking about a 85mm or 86mm on a 87.2mm crank but ran into the same issue you are having. Not much support in that range.
Look here.
THANK YOU.
