New Drive shaft shop axles and mfactry lsd (what level are these axles)
Old Jun 15, 2010 | 02:39 PM
x-s-i-v's Avatar
Default New Drive shaft shop axles and mfactry lsd (what level are these axles)
i pick these up for my da6 integra
the 450hp b16 teg
a
im not sure what stage these are supsto be
ive got a set of 26-20.5-15 mt et street dot slicks
will they suit
im got a mfractroy lsd and carbon syncros for the new box
the gear box casing is a ys1, ive modfyed it to fit the bigger diff,
the ys1 gear set it worn, i was looking at getting a new gear set our of another stock box.
maby a y80
or s80
Old Jun 15, 2010 | 02:59 PM
1FASTHF's Avatar
Default Re: New Drive shaft shop axles and mfactry lsd (what level are these axles)
I believe those are the old stage 5's.i think they are now known as the 3.9's could be wrong though.
Old Jun 15, 2010 | 03:57 PM
x-s-i-v's Avatar
cheers
will they be ok with 26" dot slicks
do i need to run drive shaft shop hubs
Old Jun 15, 2010 | 04:26 PM
I.C.C.'s Avatar
The old stage 5's/ new 3.9's included a larger hub...
Hard to tell by the pics but I would say these are 2.9's...
Old Jun 15, 2010 | 04:29 PM
1FASTHF's Avatar
if they are the 3.9's 26's might be a little much for these axles although i know a couple of people that have done it.i know a couple of guys that have been using these axles on 700hp+ cars on 24.5's without any issues and yes you need to change the hubs out if they are the 3.9's.
Old Jun 15, 2010 | 07:32 PM
x-s-i-v's Avatar
they did come with hubs, but they are install on a drag car, i think im going to need to get some hubs
TURBOFTW
May 6, 2014 04:56 PM
usmcpab
Transmission & Drivetrain
Jun 5, 2009 09:10 PM
darrinbrewer
Jun 16, 2008 04:55 PM
1point5CRX
Dec 9, 2003 08:52 PM
