Ball Joint/Tie Rod help
Old Jun 15, 2010 | 09:56 AM
cticknor666's Avatar
Default Ball Joint/Tie Rod help
Ok just a quick question. Replacing my wheel bearings and im at the point where i can put it back together. However when i try snug the castle nuts back on, they just turn and turn and i cant tighten the nut. Any suggestions?
Old Jun 16, 2010 | 10:21 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Ball Joint/Tie Rod help
use a jack to jack up the lower control arm with the ball joint going through the hole of the LCA. The lower control arm hole is tapered, so the more load you put on it, the harder it is for the ball joint to spin.
Really, you should probably replace the ball joint if it is doing that. They shouldn't have a whole lot of movement.
Old Jun 17, 2010 | 03:35 AM
Tyson's Avatar
The problem is the catle nut.
Buy a metric tap and chase the threads on the nut.
10x1.25mm for the tie rod
Or buy a new nut. Oem only.
Old Jun 17, 2010 | 10:33 AM
hatchet_honda's Avatar
does the whole balljoint turn or just the nut wont tighten up? id zap it with an impact real quick to get the nut tight then torque it to spec
Old Jun 17, 2010 | 11:35 AM
91GEDHATCH's Avatar
Mine are doing the same thing, few seperate sources told me that it was time to just replace them altogether. Not too expensive through ebay. I managed to get at it with vice grips to get the nut on last time but yeah, I was told that's the first signs of them showing too much wear. Lates man!
Old Jun 17, 2010 | 06:07 PM
Gmoney400's Avatar
same **** happened to me, replaced the joints was my easy solution haha
BCGARAGE_ED7
13
Feb 11, 2013 01:47 AM
OblivionLord
Jan 14, 2010 07:21 AM
EFin' Kyle
Mar 31, 2009 05:08 PM
chibiko
Jun 6, 2007 08:45 PM
Nameless RB26
Jul 27, 2003 10:17 AM
