obd1 conversion (trying to wrap my brain around it)
Old Jun 15, 2010 | 09:21 AM
rick_rabies's Avatar
I'm not Rick!
Default obd1 conversion (trying to wrap my brain around it)
ok. so im trying to read up on this obd0 to1 conversion....but im lost.
plz be patient with me on this
i tried to read the stickies about it.
is it not like the obd2 to 1 conversion?
i see there is a whole conversion..(whats the dif between jus the ecu jumper?)
http://cgi.ebay.com/ebaymotors/ws/eB...category=33598
im not really sure about the wiring.
the link shows a harness dealy. i plug an obd1 ecu into it and run the wires to the repective sensors on the motor?
Old Jun 15, 2010 | 11:11 AM
crx_si-r's Avatar
Default Re: obd1 conversion (trying to wrap my brain around it)
In all honesty, the wiring is the same. Only the actual pin location are swapped around. This is why the ecu jumper is used.
Old Jun 15, 2010 | 11:26 AM
I'm not Rick!
so..jus buy the ecu jumper?
basicaly i just want to be able to use an ostrich 2.0 with my p28
and swap in a z6 motor
Old Jun 15, 2010 | 11:45 AM
HondaPartsHero's Avatar
Technical Hero
yeah just buy the ECU jumper, run the wires for 4 wire O2, VTEC solenoid, VTEC pressure switch on that subsubharness on there. Look's like they used 9 wires. Probably extra wires for knock sensor and IAB's (=9 wires). Its pretty straight forward but you'll need an OBD0-1 distributor adapter.
Old Jun 15, 2010 | 11:49 AM
I'm not Rick!
ok thanx.
i do have an obd1 dizzy. can i just throw that on?
plugs are diff huh? (i havent had time to stare at stuff under the ed hood yet)
Old Jun 15, 2010 | 04:53 PM
crx_si-r's Avatar
Yes plugs are different. You can re-pin your current obd0 harbess to an obd1 plug. I don't Luke this method because if anything happens then you can't quickly comvert back to an obd0 dizzy. Pm me, I sell obd0 to obd1 distributor jumper harnesses and can make you a vtec subharness if you need it.
chrysanderson
Nov 4, 2010 12:38 PM
craig88crx
Mar 16, 2010 04:36 PM
dylokjai
Apr 19, 2007 02:43 AM
CRXVTEC69
34
Apr 2, 2005 08:57 PM
AshlandSi
Apr 2, 2002 08:45 PM
