Has my ECU been chipped?
Has my ecu ever been chipped or socketed based on this picture? I am fairly sure that it has not but I don't know much about ecu chipping. Just want to make sure it's a virgin ecu. Thanks for the help.
what you would look for are components still in the area bordered by the dashed line (C51, C52, IC3, IC4, R52 and J1) or empty or burnt looking solder joints in any of these locations.
in the case of a chipped ECU all that would be necessary to revert to stock is to cut/remove (depending on the type of jumper) the jumper at J1. not that you needed to know that... but maybe someone else will.
ive had to where this had been done. one i knew because the guy told me and the other because they left in a component (which i later used)
b4spaceage
Feb 3, 2006 03:57 PM
