1996 Honda Accord LX 2.2L F22B2 Engine No power and Unable to Rev Above 3000rpm
Old Jun 15, 2010 | 06:35 AM
cfkreider's Avatar
Default 1996 Honda Accord LX 2.2L F22B2 Engine No power and Unable to Rev Above 3000rpm
I am working on a 1996 Honda Accord LX with a 2.2L F22B2 engine with a manual transmission. When in neutral it will limit the rpm's to 3000rpm. When driving, it bucks and carries on when it gets close to 3000rpm and has no power. I replaced the distributor cap, plug wires, plugs and the valve cover gasket(plug holes had oil in them). It ran bad before doing all that. It seems to idle smoother and run smoother up to 300rpm but runs terrible on the road. It also has an exhaust leak close to the catalytic converter. What should I look at next?
Old Jun 15, 2010 | 06:47 AM
GhostAccord's Avatar
Default Re: 1996 Honda Accord LX 2.2L F22B2 Engine No power and Unable to Rev Above 3000rpm
Is the check engine light on? If the CEL is on I would suggest retrieving the stored codes from the ECU and go from there.
An exhaust leak near the O2 sensor would probably affect the operation of the car. Specially if it is large enough to alter the air to fuel ratio that the O2 is reading.
Tyler5451
Nov 6, 2017 09:52 AM
PsXtreme
Sep 9, 2016 07:30 AM
a.j.1990
Jun 5, 2012 09:49 AM
Ufretin
Aug 22, 2011 09:01 AM
Maachan513
Jun 13, 2008 04:39 AM
