Honda S2000 Honda S2000
click noise coming from the rear end?
Old Jun 14, 2010 | 10:58 PM
S2KRIDERAP2's Avatar
Default click noise coming from the rear end?
when im pulling out of first gear, it happens when i am going from a dead stop, it sounds like its coming from the right side of rear end area....could it possibly be the rear axle? i dont know how to describe the sound but its an annoying click....please help.
Old Jun 15, 2010 | 06:16 AM
JulieU's Avatar
Default Re: click noise coming from the rear end?
Could be just the axle nut needing to be re-torqued. Had that issue on my 2003 just recently.
http://www.s2ki.com/forums/index.php?showtopic=407929
http://www.s2ki.com/forums/index.php?showtopic=374235
Old Jun 15, 2010 | 11:12 AM
Spykee's Avatar
Yep more than likely the axle/hub nuts, its a common problem that you can normally fix yourself as long as you have a torque wrench big enough!
Mine wouldnt come off with an airgun at first though so not everyone has it easy.
If it still clicks afer that it could be the CV joints.
Old Jun 15, 2010 | 11:35 AM
JulieU's Avatar
^ Yup... or wheel bearing.
Old Jun 19, 2010 | 06:55 PM
Jrbs2k's Avatar
is this something that needs to be taken care of as soon as possible or...?
Old Jun 20, 2010 | 05:13 AM
Spykee's Avatar
Well you may as well try tightening the hub nuts first seeing as its free or then change them for the sakes of a few $ a side.
If its your wheel bearing like Julie has suggested and it starts to turn into a loud whirring or clattery, grinding noise then do it ASAP unless you want to risk the wheel hub sheering off driving down the road!
gilhurt
Honda CR-V & Element
Mar 3, 2024 06:56 AM
2n-chilli
Honda S2000
Aug 22, 2011 01:44 AM
desi01
Dec 18, 2009 04:40 AM
bigdogadam
Honda S2000
17
Sep 28, 2009 01:19 PM
pbizzlegsr
Mar 8, 2005 10:13 AM
