Flywheel cover bolt sizes?
Old Jun 14, 2010 | 02:35 PM
EJeff8's Avatar
Default Flywheel cover bolt sizes?
Anyone know the cover's bolt sizes? I've been told M12x 1.0mm but that seems like a rare bolt. Wouldn't a M12x 1.25mm be more reasonable?
Old Jun 14, 2010 | 03:20 PM
Corksil's Avatar
Default Re: Flywheel cover bolt sizes?
erm, that depends. honestly I dunno what you're talking about.
but on my 94 del slo vtec b16a3, the flywheel cover bolt sizes (i assume you're talking about the little metal cover on the bottom of the transmission that covers the flywheel...) is held on by several 10mm and several 12mm bolts.
as for the shank if the bolt, i gotta gtfo because i have no idea.
in my experiences, hondas don't use rare bolts. there are millions of hondas around.
Old Jun 14, 2010 | 03:40 PM
EJeff8's Avatar
Yeah, I'm talking about that cover. The yard I bought it off of said an M6x1.0mm with a 10 mm head while I heard M12x1.0mm (which sounds ridiculous) from someone else. The dude at Autozone said the M6's are much more reasonable.
Old Jun 14, 2010 | 04:18 PM
Corksil's Avatar
how about you spend 40 cents and buy two bolts, then see which one it is and settle it for us all?
i have my flywheel cover bolts sitting next to my torn apart motor, but i'm not home.
Old Jun 14, 2010 | 04:56 PM
BryanM.'s Avatar
Resident Gearhead
Regular 10mm bolts found throughout the engine bay/car. About 3/4" long.
If you don't have a ton of extras somewhere, you're not a true Honda guy
Old Jun 14, 2010 | 04:59 PM
Corksil's Avatar
but how big is the bolt itsealf. the shank of the bolt with the threads.
Old Jun 14, 2010 | 05:07 PM
BryanM.'s Avatar
Resident Gearhead
Bense says M6x1.0
https://honda-tech.com/forums/tech-misc-15/common-honda-bolt-thread-pitch-size-dimension-1885652/
Originally Posted by Bense
M6-1.0 --- common (most of our 10mm head bolts)
As far as length goes, just use ones that aren't too long. It's just a freakin' sheet metal cover.
Old Jun 14, 2010 | 05:28 PM
EJeff8's Avatar
Cool, I have the M6x1.0's! But I tried them and I think they're far too short. And yes, it may only be a piece of metal but I'm only one large kick back into my flywheel from F - ing something up, you know?. Also, I think it could probably dampen the sound my downshift makes. Probably not much, but anything is worth a try, the plate was 5 bucks.
mnmsddy
26
Feb 24, 2010 05:39 AM
c0d0r
Mar 29, 2009 02:22 PM
txsynergy
Aug 31, 2005 04:42 PM
giooooo
Feb 6, 2003 08:25 PM
