Clutch switch or interlock switch question
Ok i have a 95 civic cx that had a electrical fire and i was given a wiring harness out of a 93 or 94 coupe with a atuomatic wiring harness. I believe the reason the vehicle wont turn over is because the ecu is looking for the clutch switch signal with my wiring harness doesn't have this connection how can i trick the ecu or whatever device reads this signal the allow the starter to spin even in gear?
