FL S14 highly modded for trade.
Old Jun 14, 2010 | 10:05 AM
drifthappy's Avatar
Default S14 highly modded for trade.
Ok well Iv had this 240 for about 5 years, its been a perfect DD. Iv always wanted a s2000 so I thought I would throw it up on the forums and see if anyone would like to trade?? If someone did want to buy it ill start at 9,000.
I know im not going to get any mint s2k for this 240. Im just throwing it out there to see if anyone is interested. I am open to other trades besides a s2000.
Here is the list:
Iv never dyno'ed the car but its prob around 400whp
Engine:
S15 sr20det
Engine was re-built about 10,000 miles ago.
ACL main bearings
ACL rod bearings
ACL thrust washers
ARP headstuds
Apex headgasket
OEM rings
Balanced crank
Block and head both hot tanked
PDM 262 268 cams
BC springs
BC retainers
OEM oil pump
EVERY gasket and seal NEW
Peak Perfomance thermal intake gasket
OEM Valve guides
Mild port and polish
Must casting marks in head are ground down
DBfab Exhaust manifold
DBfab turbo elbow
Evo 9 turbo
Tial Q 50mm BOV
Peak preformance magnetic oil drain plug
stainless turbo lines
Apexi intake
Z32 MAF
Apexi exhaust
Trust downpipe
Greddy Rocker arm stoppers
Kazama motor mounts
Nismo tranny mount
Nismo FPR adapter
Aero FPR
Tomei 740 injectors
Walbro fuel pump
Electronics:
Apex power fc and commander
VIPHID's
PLX wideband
Greddy boost guage
Greddy turbo timer
Suspension / Wheels / Breaks / Drivetrain :
Stance GR+ coilovers
Nismo power brace
Tein tie rods and tie rod ends
Nismo tension rods
Adjustable toe rods
Adjustable Rear upper controller arms
Stance camber plates
DBfab rollcage (fully welded in)
Z32 front and rear breaks
OEM brake pads
Stainless brake lines
New front wheel bearings
DBfad brake sheild
MB weapon rims
Spec clutch
Stainless clutch line
KA tranny
DBfad brake sheild
s15 diff
Cooling:
V-mount set-up done by DBfab
Koyo radiator
DTM intercooler
Trust oil cooler
Moroso inline radiator fill
Moroso radiator cap
Stainless steel radiator lines
Other Stuff:
Recaro pole postion
RJS harness's
Nardi sport rally 350mm suede
Nismo "*****" shift ****
Flocked dash
Extra Stuff:
S15 rear sub frame
S15 axle's
The bads:
No a/c
No p/s (I do have all the stuff for p/s I just need to hook it up)
Needs paint and Some body work.
Old Jun 14, 2010 | 09:33 PM
srt4mike's Avatar
Default Re: S14 highly modded for trade.
Bump for viewing.
danedoremus
Oct 15, 2012 09:56 PM
TopEndTuner
Nov 19, 2009 03:59 AM
Hagakure
Northern California (Sales)
Oct 5, 2008 03:26 PM
frankdatank
Sep 29, 2005 04:48 AM
3rdGteg
Sep 27, 2002 05:56 AM
