1989 Prelude SI flasher relay location
Hello, I am new to the forum....please be easy on me if this topic has been gone over before. I tried to search for the answers and could not find them. My left side turn signal/hazard works fine....the right does not work at all....it also does not flash or click on the dash. I think the flash relay is the culprit...problem is I can't find the stinking thing! PLEASE HELP!
Yeah, I got two fresh bulbs...and nothing. I have looked under the hood, and none of the relays are marked flasher, I have also looked around the interior fuse box with no results.
Thanx for the help. I found it. Just followed the clicking noise. It is just left of the foot rest behind the what I think is the ECU, I couldn't see it until I pulled off the corner molding.
Did the relay end up being the problem because my blinkers are having the same issue and I can’t figure it out
