How to wire the DX distributor wires to the SI
Old Sep 13, 2002 | 03:49 PM
Elmdale's Avatar
Default How to wire the DX distributor wires to the SI
I need help wiring the DX distributor wiring to the SI distributor. The DX's plug does not fit with the SI. Anybody knows what to do?
Thanks
its a 1990 dx to a 1990 si motor
Old Sep 13, 2002 | 04:34 PM
VTECVillain's Avatar
Default Re: How to wire the DX distributor wires to the SI (Elmdale)
You need the plugs from an Si engine harness. You can also unpin the wires and connect them directly together.
Old Sep 13, 2002 | 08:37 PM
ghettocrxsi's Avatar
Default Re: How to wire the DX distributor wires to the SI (VTECVillain)
http://www.angelfire.com/dc/oregonimport/dx.html
thats my website... its a direct link to what u need to convert from dpfi to mpfi... I made it while we were swaping one of liek 10 motors... honda are too damn easy
Old Sep 14, 2002 | 06:42 AM
Elmdale's Avatar
Default Re: How to wire the DX distributor wires to the SI (ghettocrxsi)
so is it possible to use the dx dist. and just unpin the wires plus add the two new wires and connect them directly w/ each other....or do i need to use the si dist. and plugs?
Old Sep 14, 2002 | 07:01 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
This is how I connect a DX distributor plug on an Si distributor plug.
Take both plugs next to each other and heat them up really good with a propane torch. Make sure they are nice and soft, then put them in a vise and squeeze the crap out of them while applying heat with the propane torch.
let them cool, and voila! Works every time.
Now, if you want it to work too, then you will need an Si harness distributor plug. Make sure the Si plug has some wires still in it so you can match them with the DX wires.
You will have to add 2 wires for the CYP.
Remove all the pins out of the DX plug and match them to the same position on the Si plug.
You will need an Si distributor. The DX will ONLY work on a DX DPFI engine.
92coupe
12
Nov 5, 2010 08:30 PM
crxben
Oct 25, 2006 02:44 PM
RaysBoomBoomLude
Aug 26, 2005 02:44 PM
JustLooking
Oct 9, 2003 10:10 PM
xci_ed6
Dec 23, 2002 02:40 PM
