-10an fittings for bosch 044 fuel pumps???
Old Jun 14, 2010 | 08:18 AM
sgnlab's Avatar
Default -10an fittings for bosch 044 fuel pumps???
Does anyone make -10an fittings for the bosch 044 fuel pumps???
Old Jun 14, 2010 | 08:31 AM
airwalk07143's Avatar
Default Re: -10an fittings for bosch 044 fuel pumps???
Yes. Just got mine from summit. I had to call them and have them give me the part number though. just tell them you need a 12x1.5 to -10. Thats for the outlet. I cant remember the thread pitch of the inlet.
Old Jun 14, 2010 | 08:43 AM
xsi-t's Avatar
here is where i got mine hope this helps
http://www.jayracing.com/index.php?m...products_id=40
Old Jun 14, 2010 | 09:03 AM
em_at_kfi's Avatar
We have them.
18mm inlet.
Old Jun 14, 2010 | 10:38 AM
tony1's Avatar
Why not just run the right size line? -10 is huge for a pump that small.
Old Jun 14, 2010 | 10:52 AM
sgnlab's Avatar
Well just really looking for it on the outlet side of it when it goes to one like I didnt really want to come out with a -8 line out of them.
Old Feb 24, 2011 | 10:34 AM
swapshop's Avatar
Hey Tony > what size fuel line would u run your twin bosch 044 setup with dual sump outlet with filters ? Just so we all know what the RIGHT size line to use is ? Thanks !!
Old Feb 24, 2011 | 10:43 AM
ssc_thomas's Avatar
I'm not trying to speak for Tony but in looking at his setup I believe he is running -6 lines.
Old Feb 24, 2011 | 10:48 AM
tuhboek's Avatar
Good question im in the same boat as you....I have a fuel cell with 2 -8 feed bungs....should I run 2 -8 lines into two seperate 100 micron filters then to the pumps and than a Y to a single -10 line?
Old Feb 24, 2011 | 10:51 AM
MrParks's Avatar
18mm to -10 inlet. 12mm to -8 outlet. we stock them.
Old Feb 24, 2011 | 10:58 AM
tony1's Avatar
I use -8 inlets and -6 outlets.
Old Feb 24, 2011 | 11:12 AM
miller's Avatar
-8 feed and -8 outlet is all I use and thats what I use on my car. -10 is overkill.
Old Feb 24, 2011 | 11:24 AM
96 GSR-T's Avatar
Will -8 after the 2 pumps Y be enough for 800+ on E85 as well?
Old Feb 24, 2011 | 01:00 PM
tuhboek's Avatar
So Tony and Miller you guys are saying to use -8 or -6 AN fitting on the pump inlet and outlet with say -8 and -10 line? Or are you saying to use -8 or -6 AN fittings with the corrsponding line size? For say 800+ hp on dual Bosch set-up
Old Feb 24, 2011 | 01:07 PM
heavy duty's Avatar
Well does anyone make a 8an to 10an y. To run the two pumps together.
Old Feb 24, 2011 | 01:28 PM
B R Fittings's Avatar
Yes we carry those. It has two -8's and one -10. We also have them in all -8.
-8 is more then enough for any fuel setup for our hondas.
Old Feb 25, 2011 | 01:46 AM
hamedius's Avatar
This is how I see it, -8 is 1mm bigger than the M18 inlet and -6 is 2mm bigger than the M12 outlet.
imo it'd just be a waste of money to go bigger than -8 in and -6 out on the 044.
Old Feb 25, 2011 | 08:45 AM
raene's Avatar
-10AN lines is like a built-in surge tank. Heh...
dantamparacer
Aug 21, 2011 05:18 PM
elmalouno
Aug 20, 2010 11:17 AM
atlplayer4life90
Sep 2, 2009 04:30 PM
Crashoveride1913
Jul 16, 2008 12:31 PM
94civicx
Jul 19, 2004 07:36 PM
