how do you splice and solder wiring harnesses?
Old Jun 14, 2010 | 04:23 AM
HT Chaplain's Avatar
Loved
Default how do you splice and solder wiring harnesses?
Is there some kind of connectors you can buy or are you guys braiding the the wire before soldering and heat shrink? I cant find any type of solder connector? can you post something that you use? thanks
Old Jun 14, 2010 | 08:02 AM
onefstek's Avatar
Default Re: how do you splice and solder wiring harnesses?
I take the two wires and stick the strands of one wire into the other one. Then I solder them togheter and then heat shrink them.
Old Jun 14, 2010 | 08:35 AM
mikesrex's Avatar
when you solder, you just solder the wires together without any connectors. be sure to slide the heatshrink over one of the wires before soldering so you can put heatshrink over the solder afterwards.
Old Jun 14, 2010 | 08:50 AM
Loved
i used to live in Nederland 1998-2005
seanclark
Audio / Security / Video
Mar 26, 2012 11:22 AM
cehcivic15
Feb 8, 2009 09:43 AM
highmilehatch
Jul 24, 2003 02:09 PM
