98 civic EX no start. Replaced several parts. INPUT NEEDED
Old Jun 13, 2010 | 06:21 PM
FSS13foxtrot's Avatar
Default 98 civic EX no start. Replaced several parts. INPUT NEEDED
98 civic EX A/T . will turn but will not start. I replaced the ignition coil and rotor. when i put the key in the on position and put it out of park, i hear clicking from the main relay and the D FOR DRIVE box stays on , on the cluster. it stops clicking when in park and neutral then clicks only in other gears(clicking from relay is consistant tick tick tick tick.....). I have not swapped out the relay yet. I want to know what you guys think before i even go there.... maybe someone had same problem or knows what this is causing no start.car was running fine before this happened. THANKS -Dan
Old Jun 13, 2010 | 06:55 PM
XskylineX's Avatar
Default Re: 98 civic EX no start. Replaced several parts. INPUT NEEDED
Checked for spark, fuel, battery ok?
Old Jun 13, 2010 | 09:17 PM
mark11017's Avatar
is fuel pump priming also ?
Old Jun 13, 2010 | 09:32 PM
Steamer123's Avatar
when you turn the ignition on, do you hear the main relay and do you hear the fuel pump priming?
Check if you have spark.
Also check the ECU for codes to see what may be wrong.
Does your engine light stay on or go away just before you srart?
Old Jun 15, 2010 | 12:29 AM
i do hear the fuel pump prime, and main relay does a weird consistent clicking noise when took out of park or neutral. also when i move shifter slightly while in park it does the constant tick tick tick tick tick etc.... i will check for spark again, i did find it to be sparking, and i checked grounds. injectors are also my other thought. however there was fuel in the rail when i cracked the 17mm bolt on the end of the rail. i will have access to car on friday. thanks for input and i will take them all into consideration. updates to be posted
Old Jun 15, 2010 | 12:30 AM
battery i know is perfect. i swapped out the dead one for mine when i ran all of these tests.
Old Jun 15, 2010 | 12:58 AM
Corksil's Avatar
spark yes? pull a plug and look at it.
fuel from the rail should be fine. no fuel problem.
i'm sure it's getting air unless a duck died in your intake.
so timing would have to be off if all that is working ^^
or the main relay, but if you hear the fuel pump prime and then a click, it should be fine. that sounds weird with it's constant clicking.
yossi6780
Jul 25, 2014 12:09 PM
tech410
Apr 24, 2014 05:05 AM
Elgrys.Mendez
14
Aug 5, 2011 01:26 PM
Si-Samuri
29
Jun 19, 2008 05:48 PM
uszcrx
24
Sep 9, 2006 01:05 PM
