98 dx radiator fan does'nt work
Old Jun 13, 2010 | 05:00 PM
pliskin8's Avatar
Icon2 98 dx radiator fan does'nt work
my hatch's rad fan was'nt working so i replaced it a couple days ago, some guy was parting out his car so i got it from him....installed it.....and it still does'nt work, checked the fuse in the engine bay but thats good, any suggestions on why its not working??
Old Jun 13, 2010 | 05:14 PM
Former User's Avatar
Default Re: 98 dx radiator fan does'nt work
Jump the fan switch on the thermostat housing. If the fan now works, bleed the cooling system and then replace the switch. If none of this works, test the fan relay.
Old Jun 14, 2010 | 12:24 PM
pliskin8's Avatar
"Jump the fan switch on the thermostat housing" how do i do that
Old Jun 14, 2010 | 01:34 PM
Unplug the 2P connector and short the two terminals of the wire harness connector with a short piece of wire (jumper wire).
Old Jun 14, 2010 | 03:09 PM
ek4_b16a's Avatar
if you jump the clip itself (engine harness) and the fan kicks in, then you need to just replace the coolant fan switch itself.
Old Jun 14, 2010 | 03:39 PM
HondaPartsHero's Avatar
Technical Hero
unplug the fan, get a voltmeter and make sure it is getting power. The easiest way is to turn on the AC and see if the plug gets 12v. If not you may have a bad relay. If you do get 12v as both the fans cycle on and off you may want to look at testing the fan switch.
Old Jun 14, 2010 | 04:21 PM
pliskin8's Avatar
I'll give them a try, i dont have alot of knowledge when it comes to electrical so thanks for your help
Old Jun 14, 2010 | 06:25 PM
eghatch9295's Avatar
Stancetard Hate Monger
temporary (cheap) fix- run a switch for it, turn it on yourself. my $300 accord works like that
Old Jun 14, 2010 | 07:16 PM
pliskin8's Avatar
good idea, how did you do it??
Old Jun 14, 2010 | 07:23 PM
95EG2's Avatar
wire it to ur ignition so it turns on when ur car is on... one thing u dont what is a overheated honda motor
Old Jun 14, 2010 | 08:22 PM
EL Vap133's Avatar
I use the old paper clip trick.
Old Jun 14, 2010 | 08:26 PM
/\ that idea sucks. why would you want your car overcooled? Unplug your fan, either splice the 2 wires or cut the end off, and strip the insulation back. run power from your battery directly, or something that is 12v. if you run straight to your battery, a fuse is a good idea. google how to wire a switch
Old Jun 15, 2010 | 03:08 PM
pliskin8's Avatar
i jumped the fan, and its working fine. will it be okay if i just hook up the fan directly to the battery so i can drive it around while i get it fixed
evoluti0n12
39
Oct 27, 2015 11:03 AM
Si joey
Oct 21, 2015 09:39 PM
Bleakened
Jun 29, 2013 10:30 AM
4DRmafia
Sep 6, 2004 05:19 PM
wsiracerz
Jun 4, 2004 12:30 AM
