f22b2 block/f22b1 difference
Old Jun 13, 2010 | 03:11 PM
jthrasher1's Avatar
Default f22b2 block/f22b1 difference
im wondering if there is a difference between the f22b2 block and the f22b1 i got a f22b2 now and i want a spare to build well pretty much just a block and i found an f22b1 for cheap wondering if i could build the f22b1 block and use my head and be fine thanks
Old Jun 13, 2010 | 05:54 PM
HonBeer's Avatar
Default Re: f22b2 block/f22b1 difference
I know the f22b1 has a main stud girdle. B1 block has a windage tray also the b2 does not. Thats just one things among others.
Old Jun 13, 2010 | 07:22 PM
GhostAccord's Avatar
Aren't the crank gear and water pump different as well? 1 more or 1 less tooth IIRC. Other than that the block design is pretty much the same. OBD1 & OBD2 have there differences but the blocks them selves don't change. Just the parts that are bolted to them.
eg:R
Apr 19, 2014 08:56 AM
Chicas
Oct 28, 2009 02:27 PM
preludesi93-arg
Jun 19, 2005 06:44 AM
