a/c filter for 2002 rsx
glove box, you push both sides in and the glove box will drop, and there is a little white clip you push and it pops up and you pull it out, make sure you look at the filter because its says which way the air flows
This may or may not be the correct one, depending on the OP's request.. What you are describing is usually refered to as the cabin air filter. The AC has a seperate filter.
dom93hatch
Jun 27, 2006 07:07 AM
