idleing then stalling issues on my 96 del sol
Old Jun 13, 2010 | 01:23 PM
donmeca2020's Avatar
Default idleing then stalling issues on my 96 del sol
well not sure if a few of you seen it but i recently had brake problems i ended up taking it to a shop to get fixed.. probleme solved now today car was running great so we're driving home all of sudden we hit a stop light waiting, mind you the A/c is full blast car is neutral and then when the light hit green car is DEAD.... i had to restart and keep the RPMS above 1,000 so what would you all think the problem is? needs a tune up? MAF sensor? or what any help will be appreciated.. Del Sol gods chime in i know this must have happen to at least one of you. Once again thanks for any info
Old Jun 13, 2010 | 02:12 PM
Former User's Avatar
Default Re: idleing then stalling issues on my 96 del sol
Any CEL codes?
Otherwise, start by cleaning the IACV.
Old Jun 13, 2010 | 02:15 PM
theres is definetly a check engine light it goes on and off since ive bought the car in december, guy i bought it from says its the pcv valve and thats it. as for this problem this just started today...
PULL the CEL codes.
Old Jun 13, 2010 | 03:11 PM
TheCivicMafia's Avatar
Well, PCV valve can cause Oil leaks in main seals, oil pan seals. I'd just start by replacing the 3$ Part. Then go from there.
Old Jun 13, 2010 | 04:06 PM
Well no, but bad piston rings causing excessive blow by gas would.
Old Jun 13, 2010 | 04:11 PM
no... i dont believe it to be leaking... but once again im just curious as to what would make the car stall so quietly and gentley that i wouldnt know until i try gasing the accelerater
Old Jun 13, 2010 | 04:19 PM
I'll risk repeating myself -- pull the CEL codes and clean the IACV!
Old Jun 13, 2010 | 05:04 PM
check the cel codes tomorrow ill keep everyone informed
Old Jun 25, 2010 | 07:36 AM
it was PO441 which leads me to believe its that pcv valve... can anyone show me a pic of where the valve is located? its a 96 del sol si
Old Jun 25, 2010 | 07:56 AM
EVAP system problem. Start by checking all the vacuum lines.
Old Jun 25, 2010 | 08:05 AM
check how to see if their loose, damaged or unplugged?
masoncompton
Oct 2, 2014 12:46 PM
jdmjim
Jul 28, 2012 08:01 AM
cachase1
Feb 3, 2008 08:49 AM
als1517
Jun 27, 2003 05:49 AM
