FS: B-series Parts, DelSol Seats, GSR Head, Si brakes, Rear disc conv, lotsa good ish
Loc: 10954, NY - Willing to meet up within 20 miles
Contact: todaparty@gmail.com or PM (also email me for items with no linked pics)
This stuff needs to go ASAP!! I am Moving very soon!
Please do not PM me asking what my lowest price is. My lowest price is what I put on here. If you have another offer in mind, then give me a number, and we'll try to work it out. Like I said, I need most of this stuff gone by July Thanks!
I've been an HT member since 2001, and I'm Paypal Verified with over 300 transactions, buy with confidence. https://www.paypal.com/us/verified/p...%40gmail%2ecom
All prices include shipping to the lower 48 AND paypal charges unless stated as pick up
SOLD STUFF
- 3" stainless downpipe with 5-bolt T3 flange and flex pipe - SOLD
- Hondata thermal intake manifold gasket - SOLD
- ITR Throttle cable - SOLD
- Civic Si Brake Master Cylinder- SOLD
- GSR Blades - SOLD
- 15x6 4x100 Sunflower wheels
http://www.hondamarketplace.com/show....php?t=2793565
- 1/2 Size Civic/Del Sol Aluminum radiator with slim fan - $225
Radiator by: http://www.wizardcooling.com/aboutus.htm
I can get the exact dimensions if you need them, but its a typical 1/2 size radiator for civic/delsol or integras with turbo setups. Email for pics.
- OBD2A (96-99) GSR ECU - $125
http://smg.photobucket.com/albums/v3...t=obd2ap72.jpg
- OBD2A Civic(96-98) 5spd VTEC engine harness - $125
Will come with both OBD1 and OBD2 injector clips
- ITR Rods - $140
30k miles on them. Mint condition, were replaced with forged stuff for a boosted setup. Stronger than GSR rods, lighter than Eagle rods -- great for an all motor setup or mildly boosted (under 400 hp) setups.
http://img.photobucket.com/albums/v3...e/P1010732.jpg
http://img.photobucket.com/albums/v3...e/P1010735.jpg
http://img.photobucket.com/albums/v3...e/P1010736.jpg
- Del Sol Seats with Green stripe - $100 picked up
On DC/EG/Del Sol rails. Green stripe. Passenger is very good condition, no rips, tears etc. Driver's has a small, quarter size hole/rip on the left bolster. Its pretty minor. I think there is also one small cigarette hole on the seat cushion where your right *** cheek would be.
Pics:
As you can see the 2 rips on the *** part aren't even really visible. The bolster hole is the only real noticeably "bad" thing about both seats. Quarter for scale purposes, not included with sale
Driver bolster hole: http://smg.photobucket.com/albums/v3...urrent=ds4.jpg
Driver small hole #1: http://smg.photobucket.com/albums/v3...urrent=ds2.jpg
Driver small hole #2: http://smg.photobucket.com/albums/v3...urrent=ds3.jpg
Passenger slight scuffing at the top part of the seat, near the stripe: http://smg.photobucket.com/albums/v3...rrent=dsp2.jpg
- Brand New, In Unopened Box DC Sports 4-2-1 B-series header - $285
2.25" collector to fit USDM cats. I was going to use this for a swap project, but never did the swap. Its brand new, in a sealed DC sports box. email for pix
http://smg.photobucket.com/albums/v3...urrent=dc2.jpg
- 95 GSR Head - $650 SHIPPED WITH PP CHARGES or $600 picked up
- Fresh street port job by CC Cylinder Heads http://www.cccylinderheads.com/main.html
- Fresh HONDA OEM Valvestem seals, intake & exhaust
- GSR valves with CC valvejob
- ITR Valvesprings & Retainers
- GSR cams
- All caps, bolts, rails, etc there
- Including an OBD1 and OBD2 Distributor (obd1 dist must be used for parts - the rotor is broken)
- Red Honda Valvecover
- Freshly flowtested, cleaned, serviced OBD-1 injectors by Cruzin Performance
http://smg.photobucket.com/albums/v3...nt=photo19.jpg
- ITR Throttle cable BRACKET ONLY - $25
- Skunk2 GSR Intake Manifold Gen 1 - $150
AIT not included
http://smg.photobucket.com/albums/v3...urrent=sk1.jpg
http://smg.photobucket.com/albums/v3...urrent=sk2.jpg
http://smg.photobucket.com/albums/v3...urrent=sk3.jpg
http://smg.photobucket.com/albums/v3...urrent=sk4.jpg
- ACT Streetlite B-series Flywheel - $125
Great condition, 3K miles on it, 12 lbs
http://smg.photobucket.com/albums/v3...ent=actfly.jpg
- OEM GSR Throttlebody with sensors - $50
TPS case is half cracked, but the clip/plug clips on fine & everything is functional
- GSR Engine Misc Parts - $ offers
- Various brackets (alternator, etc)
- Black Emissions box
- OBD1 Alternator
- OBD1 Starter
- GSR Crank pulley with PS rib shaved off (AC and Alternator ribs only...basically a hybrid OEM/CTR N1 pulley) by http://www.hondamarketplace.com/show....php?t=2448247
- Upper & Lower timing belt covers
- OBD1 OEM Oil & water pumps with ~ 70 K on them
- GSR 2 post driver side block mount
- 2 GSR Flywheels
- Unknown brand clutch, still good meat left on disc
- Various b-series engine mounts
- B16 Rear engine mount T Bracket for Bseries swaps into EK - $45
- B16 2 post driver side mount for B18 swaps into EK - $45
- B-series shift linkage with oem shiftknob - $60 - prefer pickup due to irregular size
- B-series axles & halfshaft - $100 - prefer pickup due to irregular size
- 00 Civic Si Front brake conversion $ 125 picked up PM ME FOR SHIPPING -- I'd rather not due to size & weight
Comes with calipers, pads, rotors, knuckles with lower ball joints & upper control arms
- 97 GSR Rear disc brake conversion $50 picked up
with trailing arms, rotors, calipers -- a little rusty & no e-brake cables -
- Manual Boost Controller with directions - $30
http://smg.photobucket.com/albums/v3...ent=photo3.jpg
- Walbro 255lph high pressure fuel pump DC/EG/EK - $65
http://smg.photobucket.com/albums/v3...ent=walbro.jpg
- H&R 5mm 4x100 wheel spacers - $45
http://smg.photobucket.com/albums/v3...ent=photo4.jpg
- O2 extension wire - $25
http://smg.photobucket.com/albums/v3...rent=o2ext.jpg
- ITR Front stront bar (real) - $75
It has some paint on it from when my dad repainted my garage and got some on it.
http://smg.photobucket.com/albums/v3...nt=photo10.jpg
http://smg.photobucket.com/albums/v3...ent=photo9.jpg
- Beaks EK subframe reinforcement kit for rear swaybars - $50
http://smg.photobucket.com/albums/v3...rent=beaks.jpg
- DC/EG 19mm rear sway bar $65
I believe its a suspension techniques, but don't quote me. Comes w/ the bushings for the subframe, but no end links.
http://img.photobucket.com/albums/v3...e/P1000830.jpg
- Vortech Adjustable FPR - have 1 purple, 1 blue - $40 each
- AEM 2.5” short ram tube- $35 - Bracket is cut off. No filter. Couple scratches.
http://img.photobucket.com/albums/v3...e/P1000838.jpg
- Phillips D2R HID bulbs & 03 Maxima ballasts - $100, will not sell just one unless you find someone to take the other.
http://img.photobucket.com/albums/v3...e/P1010015.jpg
- Compustar Alarm w/ Remote - $40 – Just the remote and the brain, no wiring harness.
http://img.photobucket.com/albums/v3...e/P1000907.jpg
- OBD2a (97)LS intake manifold - $ 35 pickedup, PM for shipping
http://img.photobucket.com/albums/v3...e/P1000837.jpg
OBD2a (97)LS Water Neck (back of the block)- $20 shipped
http://img.photobucket.com/albums/v3...e/P1000849.jpg
OBD2a (97)LS Thermostat housing - $40 - thermostat, coolant sensor included
http://img.photobucket.com/albums/v3...e/P1000846.jpg
http://img.photobucket.com/albums/v3...e/P1000847.jpg
OBD2a (97)LS timing belt cover - $20
http://img.photobucket.com/albums/v3...e/P1000859.jpg
LS/Bseries alternator belt - $ 15 - good condition, about 15k miles
http://smg.photobucket.com/albums/v3...t=P1000851.jpg
90 Degree mandrel bend intercooler pipe 2.5” - $25 - bead welds on the ends for sealing. Mild steel, 2.5”.
http://img.photobucket.com/albums/v3...e/P1000867.jpg
Stock EG Hatch DX Upper Control Arms Make Offer
http://img.photobucket.com/albums/v3...e/P1000616.jpg
SOLD STUFF
- GSR Blades - SOLD
- ITR Rods - $140
Pics:
- GSR cams
AIT not included
- OBD1 Alternator
- OBD1 Starter
- 2 GSR Flywheels
downpipe, itr throt cable, intake mani gasket, si master cyl all sold -- updated thread
Toda Party
Mid-Atlantic (Sales)
Jun 19, 2010 09:29 PM
Toda Party
Northeast (Sales)
15
Jun 19, 2010 12:56 PM
4doorcivic9
Jun 26, 2009 09:36 PM
