LS swap assistance
I am dropping a OBD2 Ls motor into my 92 civic Hatchback CX. I will be running a p75 obd1 ecu and I bought the MSD 8864 to use the OBD2 distributor. I thought i did the opposite of what i am about to ask before i just can remember and just thought i would ask for sure.
Can I cut the injector clip and splice them into the obd1 harness? Will this work properly and is the impedience the same? Is the Flow the same?
the ecu is programmed for 240cc injectors and you are using the injectors designed for it so yes it will work fine. also note, most all d and b-series engines utilize 240cc engines. only exceptions i'm aware of are the d15b8 and d16y7 which used 190cc injectors.
