innovative alternator relocator help
Old Jun 12, 2010 | 08:16 PM
wek'lude's Avatar
Default innovative alternator relocator help
i just installed the innovative alternator relocator on my h23 and have the issue of the belt rubbing against the plastic timing cover...any ideas? i'm sure it's in the correct spot, don't know if it's a flaw with my particular mount or if i'm doing something wrong. thanks for any help.
Old Jun 13, 2010 | 07:11 AM
esedulerp5tenin's Avatar
Default Re: innovative alternator relocator help
looks good brian.
since i spy a bolt missing holding the timing cover on, are you sure its not missing a couple more, making the cover not seated properly??
Old Jun 13, 2010 | 07:21 AM
megomaniac's Avatar
is the balance shaft drive gear behind the pulley?
Old Jun 13, 2010 | 08:08 AM
wek'lude's Avatar
Originally Posted by esedulerp5tenin
looks good brian.
is that you nick? but anyway i removed a few of those bolts to peek behind the cover to see what the bump was covering, which appears to be the balance shaft gear i believe. it doesn't seem like the cover moves back anymore but i'll give that a try. good eye
i believe it is the balance shaft, on the bracket there are two sets of holes: one set for running the balance shaft and to the right for no balance shaft. innovative is closed on sat and sun so if i can't figure it out soon i'll give them a call on monday.
waciii
Apr 11, 2011 11:34 PM
madmike84
Apr 12, 2009 07:59 PM
bignosewhipper
25
Jun 13, 2008 07:49 AM
