Battery is full power yet starter clicks like battery is dead.
Old Jun 12, 2010 | 12:22 PM
egvtec's Avatar
Default Battery is full power yet starter clicks like battery is dead.
Car has been running great then one day i came out after letting it sit for two hours and the car wouldnt even turn over, so i jumped it thinking it was the battery, new battery later and car wont turn over, replaced the starter and same thing. So i swapped the old one back in and it clicks real fast like when the battery is dead but it doesnt turn over. Any one had this problem? i just want to drive my hatch.
Old Jun 12, 2010 | 01:14 PM
BrandonR's Avatar
Default Re: Battery is full power yet starter clicks like battery is dead.
Try checking your grounds sir. Particularly the one from the transmission to the frame. Later, BR
Old Jun 12, 2010 | 01:15 PM
egvtec's Avatar
Funny you posted that because i checked that before i came in cleaned and retightened the fittings and veeeola!
I was gonna post to let everyone know i fixed it.
Old Jun 14, 2010 | 11:59 AM
jwubby's Avatar
lucky! im still havin the problem but my start doesnt even click.. im gettin power into my starter n everything but it just wont crank over..
Old Jun 14, 2010 | 12:26 PM
apexi_rsx's Avatar
sounds like poor ground
Old Jun 14, 2010 | 03:33 PM
Corksil's Avatar
we have three components we are working with here.
power to the starter
ground from the power
starter itself
check the amperage that the starter is getting with a multimeter. check service manual to make sure it's enough.
check continuity from ground on starter to negative battery terminal.
if both of these figures check out, take out the starter and have it tested at autoparts store.
should be pretty simple fix.
Old Jun 14, 2010 | 03:45 PM
shawn_crx's Avatar
starter itself
Don't forget ignition wire
Old Jun 14, 2010 | 03:53 PM
Corksil's Avatar
same difference.
Old Jun 14, 2010 | 04:09 PM
harry81's Avatar
i think the grounds should be faulty. had a earlier problem like this. worked on it all afternoon. finally found that the grounds were giving the problem.
Old Jun 14, 2010 | 04:23 PM
si.hatch's Avatar
this happened on my ruck awhile ago, take the starter out and clean the contacts and the plunger or just replace them( pretty cheap).
should work fine after that
Old Jun 14, 2010 | 06:08 PM
EG'SUS's Avatar
I remember that happened to me once lol.. I had my friend pull my car to his house with his tow hook, then i Noticed a loose ground wire and plugged it to the stater and veeeola! also
HAHA
Old Jun 14, 2010 | 06:14 PM
eghatch9295's Avatar
Stancetard Hate Monger
dont forget main relay. they act up especially when it gets hotter outside
Old Jun 14, 2010 | 10:17 PM
BrandonR's Avatar
Good to hear sir. It's an all to common reoccurence. Later, BR
Aug 13, 2010 09:14 PM
importfanatic17
Feb 26, 2007 12:34 PM
SiB16A
Jun 11, 2006 12:37 PM
incognito E46
May 30, 2005 05:06 PM
nesabay
May 17, 2005 08:39 PM
