Andrews Family 2011 SFWD coupe build
With some good luck and alot of cash hopefully the car will be ready for the 2011 race season. Car has been in the family since 2001 and last raced in 2004. Took a few years off to build a buisness and have a couple kids. Right now the goal is to get it running and around 700-750hp and a 9sec pass. Then we will make changes to get into the low 9's maybe 8's. Will post pics as work is completed. 85% of the work was completed in our 2 car garage.
Build Consists of the following...
Block:
Benson Sleeved 84mm gsr block "Sent through Synapse" Thanks for Making it right Morgan!!
84mm Wiseco Pistons
Manley Rods
89mm stock crank
GE Block off plugs
OEM oil pump
Oem Water pump
Moroso Oilpan
ACL Race Bearings
Final assembly "Done in House"
Golden Eagle Head Studs
Oem Main Studs
Head:
B16 Head
Stock Cams "For Now"
Supertech Valvesprings and Retainers
New OEM Valve seals
Port and Polish "Done by me"
3 Angle Valve job "Done by me"
Full-Race Cam gears
Engine Management and Fuel:
Hondata S300
Speedfactory 4 bar Map sensor
Stock Distributor w/ external coil
Oem Spark plug wires
Edelbrock Intake Manifold
Professional Products 70mm Throttle body "Phreable.net"
Injector Dynamics 1000cc injectors "From T1" thanks Tony
Walbro intank
Bosch O44 inline
Stock feed and return lines
Drive Train:
Stock LS trans
Spool
5th gear Trans Cuff
Twin Disc Clutch "Not yet purchase Maybe Comp or Spec"
Stock Axles "for now"
Turbo:
Gt4294 "Bushing Version"
4" Downpipe
Forged Performance Divided Manifold "Thanks Phong" Great Cutomer service
2 Tial 38mm MVS Wastegates
3" Intercooler piping by Go-AutoWorks "Thanks Greg" He knows his **** fits perfect.
Precision 825hp intercooler
Tial BOV
Suspension:
Blox Pro Front and Rear Suspension "Not yet purchased"
Skunk2 Front camber kit
Blox rear camber kit
Wheels are still undecided
New Oem Brakes all around
Custom 10 point cage w/ window net and Chute Done By RTR services in Palmyra, NY. Big Thanks to "Mike and his sons" over there awesome job and great price.
Some parts are already purchased and some are not. This Build should be a good one.
Pics to come soon!!!
Block:
84mm Wiseco Pistons
Manley Rods
89mm stock crank
GE Block off plugs
OEM oil pump
Oem Water pump
Moroso Oilpan
ACL Race Bearings
Oem Main Studs
Head:
B16 Head
New OEM Valve seals
Full-Race Cam gears
Hondata S300
Walbro intank
Bosch O44 inline
Drive Train:
Stock LS trans
Spool
5th gear Trans Cuff
Turbo:
4" Downpipe
Tial BOV
Suspension:
Thanks for the comments. I really appreciate them.
That paint is wicked!! You have to see it in person to really appreciate it.. I had the guy at the paint store add extra pearl to it so it would flop colors and boy does it. I really dont care for it in direct sunlight because it almost looks baby blue "almost".
Mocked up some things to see how they fit and the cage getting started.
Thanks guys!!! Good feedback is always appreciated. And as far as it being a family build I wouldnt have it any other way!!! But it seems to me like im doing all the wrenching.LOL
Cage is finally complete. It came out great and fits tight. i will put up some better pics later tonight, but this is what i have for now. Taken with my phone.
[/IMG]
