Honda S2000 Honda S2000
No spark at all after coil replacement.
Old Jun 12, 2010 | 09:06 AM
THE GUY's Avatar
Not to be confused with "THE MAN"
Default No spark at all after coil replacement.
I am working on a friends 01' S2000 and it was riddled with issues. it was brought to me not running and was told that it "sounded like a WRX" then stalled and would not crank again. So I pulled the coil packs to find 2 loose spark plugs (finger tight) and 2 melted coil packs. One of the plugs had completely melted away leaving only the upper ceramic and threaded collar.
After replacing the coil packs with new OEM units and new plugs, new battery, new main fuses (all had burned at the time of issue), cleaned all debris out and compression checking it I am still not getting any spark. I was intermittently losing voltage to the packs and now nothing at all. Any ideas guys? I am about to try replacing the ECM with a known good one but after that I am somewhat at a loss of what to do.
Old Jun 12, 2010 | 02:35 PM
HondaKyle's Avatar
Default Re: No spark at all after coil replacement.
If it sounded like a WRX, Im willing to bet it was running on three cylinders and maybe miss firing.
Old Jun 12, 2010 | 03:54 PM
THE GUY's Avatar
I know it misfired, it had stored codes for random misfire in all cylinders. I'm replacing the ECM and the crank position sensor in the morning since if that sensor goes it can cause that issue as well. Such a pain to get to that sensor too. Between working on this and the damn F body I have up in the air I need a damn break. Soon as I get the S figured out I have to start getting to work on my jeep. I'll update in the morning after swapping the parts but any ideas are welcome.
Old Jun 15, 2010 | 10:35 AM
White Smoke's Avatar
i my honda
Global Mod
Make sure you check out all the wiring for shorts before you blow another ECM in the diagnostic process. Sounds like a nightmare... GL!
Old Jun 15, 2010 | 04:35 PM
THE GUY's Avatar
Actually got it started today, ECM was bad. Also all fuses and coil packs were replaced. NOw I'm dealing with getting the #1 sparkplug to thread back into it's hole. It will not catch threads even after rethreading it. MAy have to pull the head and have it welded/ re drilled and tapped.
EGLUVN
May 17, 2007 12:53 PM
gottagofaster
Oct 22, 2005 04:50 PM
BadBeck
Dec 11, 2003 05:59 PM
E Swift
Sep 3, 2003 07:07 PM
