88 crx si tranny questions & b2 to a6 questions
Old Jun 11, 2010 | 07:28 PM
CRXguy_88's Avatar
Default 88 crx si tranny questions & b2 to a6 questions
Ok, i believe i have an 88 si tranny to go with my a6 and I just bought an 88 si clutch kit.. one question is can i use the d15b2 flywheel? or no.. and also is there any write up or pics of how to put a clutch on the motor and how to ptu the tranny on the block? (hopefully a crx one) any help would be great.. thanks
o ya also could i use the crank pulley and belt off my d15b2?
Old Jun 11, 2010 | 07:38 PM
BiG ChOr!Zo's Avatar
Default Re: 88 crx si tranny questions & b2 to a6 questions
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
http://www.d-series.org/forums/trans...ng-change.html
Old Jun 12, 2010 | 06:52 AM
91_e_f's Avatar
i just used a complete clutch off of a d15b2 on a z6 block and it worked fine. if your motor is out its gonna be hard to keep it from cranking over while loosening and tightening all them bolts so what i did was got a short small screwdriver and put it through a hole in the flywheel and it will catch on the block eliminating the problem. when i did it i used a pattern similiar to tightening lugs. then once the flywheel is on use your alignment tool and torque the pressure plate and you should be in business! and i think i used a 10mm on the pressure plate and a 17mm on the flywheel. ..my bad i didnt see that about the different flywheel.. that i dont know.
Old Jun 12, 2010 | 07:55 AM
slywfbpsi's Avatar
As long as that d15b2 flywheel is off of a 1988 d15b2 then yes.
Old Jun 12, 2010 | 08:32 AM
jlicrx's Avatar
89 D15B2 flywheel is same as 88 - 90 and 91 are different
Old Jun 12, 2010 | 11:31 AM
slywfbpsi's Avatar
He didn't mention 89. Only that he had an 88 si tranny and a 88 si clutch kit. He did not mention what year the flywheel was. And by the way I have an 89 si tranny attached to my 91 dx clutch and flywheel.
Old Jun 12, 2010 | 06:11 PM
CRXguy_88's Avatar
i don't have a flywheel... well i do but i dont know what year my current d15b2 is lol maybe a 89 or 90 idk. That's why im asking.. i thought it would best if i kept it all the same year.. that true?
Old Jun 12, 2010 | 06:30 PM
slywfbpsi's Avatar
It is best if you keep it in the same year to avoid any confusion. If that flywheel is 89, then YES it will fit with that 88 clutch kit that you have, in that 88 tranny. However, if that flywheel is 90, then NO, that flywheel will NOT work with the 88 clutch kit and 88 tranny.
Old Jun 12, 2010 | 06:34 PM
i posted that first link above about the clutch and flywheel for a reason
Old Jun 12, 2010 | 06:53 PM
slywfbpsi's Avatar
Yeah, I read it and knew it. I don't know if he did.
user 98292739
May 6, 2007 12:32 PM
g_rant2006
Feb 6, 2006 08:48 AM
Floored
Jun 8, 2005 06:59 AM
theclutchpoppa
Nov 12, 2002 05:36 PM
