ep seats in and ef
i was wanting to know if any one would know or if any one has done it yet i am going to try to put ep seats in my 91 hatch let me know if u have any info thanks
if you are talking about 03+ civic si seats i have made a set fit a 88 crx witch have little bit different seat rails 88-89 90-91 differ, they did sit about 3in higher but i cut mine up and welded them to get them to sit lower, the seats are almost the same sive but back rest is taller ever after i cut the rails down
You can put any seat in there if you want to change seat rails and cut/weld. There are very few that will just bolt up if that's what your looking for. I believe only 88-91 EF seats bolt up
if you have a 91 only 90-91 seat's will bolt right in and few 89 with seat belts in the doors, most honda seats you can just swap seat pans, but after 01 they become a one peace seat pan and rail together, so you can not do pan swap with ep seats unless you weld up mounts for the back rest or they will seat way to high
FTNW
Jul 27, 2011 03:23 AM
