Fuel filler relocation
Old Jun 11, 2010 | 05:03 PM
fabmaster's Avatar
Default Fuel filler relocation
I am moving my filler tube into my door jamb so I can shave the gas door. I'll just let the pictures do the talking.
I prepped the gas door to be welded as well
Anyone have any ideas on how to bend this filler tube. I heated it today with my oxy-acet tortch and couldn't get it to bend. I should be able to just bend it to it's new location so I won't have to cut and weld it.
Old Jun 11, 2010 | 05:08 PM
essex's Avatar
Default Re: Fuel filler relocation
that was great work!
Old Jun 11, 2010 | 10:24 PM
Lugzilla's Avatar
Canuckian
Thats a pretty good idea, I'm in for seeing the finished result.
Hate to ask a stupid question but did you clamp it down to a big table? Maybe rig up a cheater bar outta some scrap metal if you have anything laying around and try it again. Just gotta get the whole pipe where you're bending red.
Old Jun 12, 2010 | 06:18 AM
fabmaster's Avatar
A guy on a fiberglassing forum I'm on said that I have to anneal it first. " Just heat it to a reddish-orange and let air cool. once it's air cooled you can heat it to a orange-yellow and it should bend for you. filling the tube with clean sand (blasting or playground sand)will help in two ways. it will hold alot of heat and also prevent the tube from collapsing."
So hopefully I can get it bent properly otherwise I'll be using rubber marine fuel tubing.
Old Jun 12, 2010 | 12:27 PM
c5R's Avatar
c5R
what size pipe did you put in the jam?
Old Jun 12, 2010 | 01:00 PM
Sobe_Death's Avatar
Is your weatherstripping still going to seal with the door jamb cut right there?
Old Jun 12, 2010 | 03:22 PM
perseverance's Avatar
only thing i'd be worried about is slamming the door, creating a spark, and bam.
Old Jun 12, 2010 | 03:27 PM
Flashmn's Avatar
I hope that was sarcasm... I dont see car doors sparking, besides its not gonna light as easy as you think
Old Jun 12, 2010 | 07:34 PM
levelzero's Avatar
Might be easier to just switch to a rubber tube.
Old Jun 12, 2010 | 07:38 PM
siblues's Avatar
Thats looks great I cant wait to see it finished.the only thing that I see may be a problem is water collecting at the bottom of the opening by the cap.
Old Jun 12, 2010 | 08:45 PM
Lugzilla's Avatar
Canuckian
Using sand sounds like your best bet, if it still doesn't work rigging something up with rubber tubing seems to be the next best thing. I still wanna know how you solved this out.
Old Jun 12, 2010 | 11:02 PM
fabmaster's Avatar
The pipe has a 3 inch ID which made for a tight but easy to use fit.
The weather stripping hits to the left of the furthest point of the tube and has about 80% of it's surface still in contact. The seal is solid all the way down still
I've been pondering that too. I'll either weld in a channel at a downward angle or drill the bottom corner and run a drain tube out the bottom of the car.
Old Jun 13, 2010 | 03:10 AM
you also don't see when you touch something and zap it because it's soo small. but... that soo small spark is what causes fires at the pump. def not sarcasm, just a concern although it may never be an issue. On the other hand, the work looks good and the idea is definitely something different.
Old Jun 16, 2010 | 08:16 PM
miguel329's Avatar
thats neat... lol people at the pump are gonna think you filling up the inside of the car with gas
Old Jun 17, 2010 | 05:56 AM
OD's Avatar
OD
thats pretty nice work thar!!
Old Jun 17, 2010 | 08:44 PM
fabmaster's Avatar
Got some filler and primer on the jamb.
After attempting the bending method with little success I also found that I needed more length anyway. I pie cut up by the filler neck and bent it to a new angle, then welded in a 3 inch piece of pipe. For the vent I was able to find tubing. I water-tested the welds and even though they don't leak I still smeared them with seam sealer.
You can see the original mount for the filler and see how little it had to move
Old Jun 17, 2010 | 09:24 PM
uberEFtuner's Avatar
I,m relocating mine to the rear of my CRX. I will be doing the same thing behind the little plastic triangle that says Honda on it. I hope I will be able to do the same idea. I,m going to use marine fuel fill hose, because its designed for this kind of thing. Bad *** welding by the way!
Old Jun 17, 2010 | 09:39 PM
fabmaster's Avatar
I couldn't get any 1.25" ID marine hose at the local boat suppliers so that's why I ended up weldig the large tube. Good luck on your relocation.
Old Jun 18, 2010 | 02:45 AM
95DC2GS-R's Avatar
very nice, in for finished work
Old Jun 23, 2010 | 05:43 PM
miguel329's Avatar
that diff neat idea
Old Jun 23, 2010 | 06:25 PM
-RedneckDave-'s Avatar
Working
Turned out great. I would love to see the whole car.
BinMop
Jun 26, 2009 05:24 AM
BauleyCivic
Mar 22, 2006 07:45 AM
nathanong87
Feb 1, 2006 12:44 AM
B16A2-EM1
May 25, 2003 08:10 PM
