MD 91 ef hatch.
EVERYTHING IS OBO(zero set prices we all know what stuff goes for so hit me up)
wtt,sell,part out
(only lump part outs) if you want the drag mani cool buy the turbo kit, if you want the hood cool buy the shell, ect)
fund my new build 90 rt awd wagon
91 hatchback civic clean title
aztec green small rust on pass 1/4 panel, no dents paint is in good condition
oem mud guards on the rear
vw front lip fits amazing
fender marker lights
crx dash conversion
grant carbon wheel
pass mirror
rear mounted battery
b18b1
avid race mounts
arp headbolts
cosmetic headgasket
b16 trans shifts great
8lb flywheel
clutchmasters stage 3 clutch
itr shift ****
gsr dual bend shifter
grant carbon wheel
all new racecraft shift linkage bushings
drag cast mani
greddy t3/t4 50trim turbo
2.5" 5bolt custom built downpipe
2.5" flex, 2.5" to/ 3" resinator, 3" full dump under rear lower control arm on pass side
2"/2.5" hot side intercooler piping
2.5"cold side intercooler piping
greddy type s bov
tial knock off 38mm wastegate 8lb spring
obd1 precision 450 injectors
obd1 distributor
obd0/obd1 conversion harness
obd1 p75 ecu (needs basemap/tune)
H&R race suspension(full coilover)
00 si wheels
no ac
no ps
not runing will need to be towed
wtt,sell,part out
crx dash conversion
grant carbon wheel
pass mirror
b18b1
avid race mounts
arp headbolts
cosmetic headgasket
8lb flywheel
itr shift ****
grant carbon wheel
drag cast mani
greddy type s bov
obd1 distributor
00 si wheels
no ac
no ps
The car is not runing due 2 no spark. I have some1 coming in a few days 2 look at it for me. It was runing and I test started it after every part I installed. When I installed the oil feed line it touched the alternator power and arked. After this no spark. The dizzy is converted over 2 obd1. There is a obd0 to obd1 conversion harness on it now. And a obd1 p75 ls ecu installed. No spark is the problem. I will sell it the way it sits now for ??? No turbo kit 3k. No kit and no seats 2500. No kit ,seats, suspension, wheels...a complete shell with swap and full interior 1800. After I get it runing and is on a base map the si wheels will be gone and will be on some other kind of wheels,unsure of what yet. But if u want it get it b4 next week cause it mayb on the move then
i have 2 oil pans. 1 thats on it with a bung welded onto it, and an oem 1.
if a tapped oil pan is the factor on buying the swap you dont really want it.
1k now or
MOTOR: 500
TRANS: 400
CLUTCH/FLYWHEEL COMBO: 150
ADVID MOUNTS: 100
LINKAGE w/RACECRAFT BUSHING KIT: 100
AXLES: 50
ECU OEM P75: 50
1k now or
MOTOR: 500
TRANS: 400
ADVID MOUNTS: 100
AXLES: 50
ECU OEM P75: 50
