need help
Old Jun 11, 2010 | 07:53 AM
metalmulisha87's Avatar
Default need help
okay i got a 96 honda civic lx
its overheating it blows the over flow hose off
i think i may have a head gasket problem?
Old Jun 11, 2010 | 08:04 AM
Sr420Det's Avatar
Default Re: need help
So the car just starts overheating after five-ten minutes of running, right? is it leaking from the waterpump? Overheating can come from a bad hg but usually the hg is blown due to overheating. We need more info, r u blowing white smoke out the exhaust? Usually when the hg is leaking itl do it alot worse at startup and the motor will skip badly until its warmed up and then not do it as bad, is urs doing this?
Old Jun 11, 2010 | 08:11 AM
nope no white smoke...n no water leaks from the water pump...also its been sputtering like when u pull up to a red light the RPM dies down past the 1000? it has trouble tryna take off again? what could dat be??? n thanks for the input
Old Jun 11, 2010 | 08:18 AM
Sr420Det's Avatar
sounds like skipping to me, thats what happens when water gets in to the cylinders through ur headgasket. Id just change the waterpump and timing belt for the hell of it when u change the headgasket. So whats the events leading to it overheating?
Old Jun 11, 2010 | 08:20 AM
loss of coolant...it blows the coolant out of the hose on the over flow...but i also found oil n the radiator?
Old Jun 11, 2010 | 09:20 AM
Sr420Det's Avatar
Id change the hg, waterpump, and timing belt. U should have the head checked for warpness or u can just put it all back together and hope for the best. If oil is n ur water its probably mixing at the headgasket.
Old Jun 19, 2010 | 08:02 AM
is it true dat u gotta replace the head bolts if ur gonna change the head gasket????
square_1
10
Sep 5, 2006 09:02 PM
Strikerrr
Jul 25, 2005 05:44 PM
Ignitecivic
Jan 7, 2005 12:36 PM
EGTeK
Jul 28, 2003 09:04 AM
TeginRAGE
Sep 11, 2001 07:18 PM
