Brake pedals are super hard and barely stop
Old Jun 11, 2010 | 01:44 AM
cityofcaterpillars's Avatar
Default Brake pedals are super hard and barely stop
I have a 97 LX Coupe. The brake pedal is really really stiff. Like when you're bleeding brakes and you're at the end of pumping kind of stiff and they barely stop the car. I have replaced everything inside the drums, frnt calipers, front lines, pads, and the power booster. Nothing has helped. The only thing I can think of is the master cylinder but I thought a bad one had the opposite effect on the pedal.
Anyone have any advice please please help. This is driving me crazy
Old Jun 11, 2010 | 04:11 PM
phootbag's Avatar
Default Re: Brake pedals are super hard and barely stop
Hook a vacuum gauge up to the vacuum hose at the brake booster and make sure there is vacuum at the booster.
Old Jun 11, 2010 | 04:54 PM
HonBeer's Avatar
No make sure the brake booster holds vacuum when the vacuum line is disconnected using a hand vacumm pump
Old Jun 11, 2010 | 05:08 PM
phootbag's Avatar
I've replaced a couple of stuck check valves in the booster lines which caused this symptom. So, yes, check for vacuum.
Old Jun 11, 2010 | 05:22 PM
ej1serge's Avatar
check both of those ^
Old Jun 12, 2010 | 02:15 AM
Balwin's Avatar
sounds like the brake booster.. undo the vacuum line on the brake booster and see if it makes a difference. if it doesnt then obviously you have pinpointed the problem
kazaa187
May 26, 2013 01:51 PM
braass91
18
Jul 19, 2012 11:38 AM
boarding2008
Jul 4, 2010 12:08 PM
veejay
Jul 24, 2001 09:39 AM
