With Kenjis ECU....
Old Sep 13, 2002 | 12:58 PM
brownman72000's Avatar
Default With Kenjis ECU....
whoever has this on their car, what redline did you ask him to make? He told me the standard ones have a 9100 redline. I have stock cams and I am wondering if they are gonna make any power after 8500 rpms? Also, do you need a FPR to make the ECU work better? Can I ask him to set the Vtec cross over point lower around 5000 rpm or is that not a good idea? Thanks!
Old Sep 13, 2002 | 12:59 PM
Doctor CorteZ's Avatar
Default Re: With Kenjis ECU.... (brownman72000)
why lower it ?
do you want to lose power?
Old Sep 13, 2002 | 01:01 PM
rainmanEK's Avatar
big strong guy
well stock cams wont make power that high, in fact very few cams will! you dont need a fpr, though i would recomend one if you plan on dyno tuning! he can set differnt vtec, though i would use wahts proven, messing with vtec, can also alter your power placement! good luck, eric
Old Sep 13, 2002 | 01:27 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: With Kenjis ECU.... (rainmanEK)
Some people have actually lowered their vtec (I believe Mike K did, I'm not sure) with stock cams and it helped smooth their plot out. You need to tune the fuel for what ever changes you make.
Old Sep 13, 2002 | 01:55 PM
Junglist's Avatar
Stock cams WILL make power past 8.5k.
where do you get you information from?
Old Sep 13, 2002 | 01:59 PM
AW's Avatar
AW
Default Re: With Kenjis ECU.... (Junglist)
Lowering the VTEC point smoothed out the curve for me. See my dyno post of my 01 ITR motor...
https://honda-tech.com/zerothread?id=278517
Anselm
pchan
Dec 25, 2007 08:23 AM
mr.roboto
Oct 17, 2005 04:29 PM
JinMTVT
12
Dec 21, 2004 08:31 PM
Dc5-Power
Apr 17, 2004 11:04 AM
