spun cam journals
Old Jun 10, 2010 | 08:44 PM
chikin pickle's Avatar
Default spun cam journals
I have removed an engine from a junked out accord for my planned F22 build. f22a6.
I have been tearing out the valvetrain this afternoon and discovered that it has three spun cam journals and the camshaft bearing surfaces are ruined.
I would like to know, is it possible to line-bore the cam journals like they do with crankshaft mains? Or should I just write off the heads and grab some different ones.
I'm going to assume here that the cam is a total write off.
Old Jun 11, 2010 | 09:14 AM
hondamark35's Avatar
Default Re: spun cam journals
Originally Posted by PirateMcFred
An F22A head is about as cheap a head as you'll ever be able to find. If it's damaged then replace the whole thing. There are millions of them.
agreed. i've also found that a "rebuilt" F22A head is can be had for less money than a set of OE replacement valves, valve seals and paying a machine shop to resurface.
Old Jun 11, 2010 | 01:02 PM
Thats kinda what I thought. Guess I'll strip the rockers and use it as a core.
Interesting tip on the rebuilt head.
evilclown312
Jul 20, 2012 01:40 AM
D16Cowboy
Apr 26, 2007 01:45 PM
PA MATT
Mar 13, 2007 12:40 PM
integrated civic
Aug 26, 2004 05:10 PM
